Results 1 to 9 of 9
Thread: How to modify Rear/Side mirrors for LCD display?
    Jul 2005
    I saw a guide on how to add a LCD display to your side or rear view mirrors, but I can't locate it anymore :/ Could someone give me information on how to do this? As I recall, they put the LCD screen behind the mirror...
    Constant Bitrate BADDERICK's Avatar
    Jun 2005
    Las Vegas
    One way glass, Like they use for line-ups...LoL, Put light behind it and you can see through it.
    2003 100th harley F-150
    PCChips C3 VIA/eden, M1 ATX smart car.
    Here is my project so far: My 100TH Harley-Puter
    Ride safe
    Buy my stuff: Stuff
    Jul 2005
    Would you hapen to have a link to a guide?
    Jun 2005
    Las Vegas
    I would think, Just get the glass cut to the right size and put a monitor behind it, Should be simple enough. I did find a link to make one way glass.
    Formula for One-Way Window Glass
    I am going to have to try this it's your friend.
    Ride safe
    Buy my stuff: Stuff
    Jun 2005
    Las Vegas
    I think I might try that on the back side of a touch screen? Should work, RIght??????? LoL
    Ride safe
    Buy my stuff: Stuff
    Jul 2005
    I searched the site using google and didn't see any relevant topics. On another search I found the info I needed:
    LED display in Rear view mirror
    Making a "window" in your mirror is a realatively easy process. Once you have your mirror glass removed and in hand you will want to use a small razor to scrape away the heavey "painted" backing (usually black or gray). This will expose the back side of the reflected "silver" surface. This reflective material can be removed with a pencil eraser. Note that anywhere you scratch away the backing "paint" your eraser strokes will remove the silver finish and make a "hole" in the reflective surface. work slow with your razor for a perfect edge and work even slower with your eraser and you will have a great finish. I typically use an electric eraser (drafting type) and a gritty ink eraser stick to work more quickly at removing larger areas. Hope this helps! post pics of your process!
    Jun 2005
    Las Vegas
    Yeah, but then you lose the functionality of the mirror where ever you scrath off the backing. if you used one way glass, When the monitor was off it would look like a mirror? I don't know if it will work, A monitor might not be bright enough behind one, But I want to see, I'll let you know.
    Ride safe
    Buy my stuff: Stuff
    Jul 2005
    I never said a monitor, I said a display. You know, those 2 line ones? Display speed, MPG, temp, etc. 3" wide and maybe 1" tall.
    Jun 2005
    Las Vegas
    So I'm thinking a little bigger:-"
  1. V1 Virtual Display : Skinnable Valentine One to PC Software
    By zPilott in forum Software & Software Development
    Last Post: 10-31-2009, 08:19 PM
  2. Any way to relocate my display card??
    By SlimJimmy in forum General Hardware Discussion
    Last Post: 03-22-2004, 10:14 PM
  3. Choosing a Character display...
    By Kryten in forum LCD/Display
    Last Post: 10-16-2003, 11:43 PM
