Results 1 to 3 of 3
Thread: Seeking Sharp LQ6RA01 information
    Jan 2002
    Frederick, MD
    Question Seeking Sharp LQ6RA01 information
    Does anyone have an info on a Sharp LCD screen?
    Specifically, I am looking for any information on buying/building an inverter for the backlight and the circuit for hooking it to VGA. I have found some circuits I am trying to modify, based on some limited material.
    If it helps, I believe the LQ6RA01 was a prototype for the LQ6NC01 and there were some relatively minor changes in design.
    Thanks,
    Brian
    FLAC mp3z24's Avatar
    Apr 2001
    Chicago Suburbs
    Post
    well i have a sharp lq6nc02 (different viewing angle than the 01) and you can get backlight inverters for them from digikey. digikey, the part number is 289-1025-ND. have a look around on digikey to make sure this one will work for you. they are about $15 each.
    ~mike
    Single Member of the "1000 Post and No MP3 Car" Club
    PROJECT ON INDEFINATE HOLD... BOUGHT A HOUSE
    2000 Cavalier Z24 [###-------] Only 30% Done ... Still
    Jan 2002
    Frederick, MD
    Smile
    Thanks, I'll check it out.
    For anyone else interested, I also found that TDK makes an inverter that cross-references with the LQ6RA01 (product key is CXA-P1212-VJL). It's a 7W, dimming model that powers both lamps. They run about $30 from TDK's distributors.
    I'll get this mp3 car project rolling if it kills me (no pun intended). With an inverter that may just happen.
