you cant cut the board. your only option is to tilt/move the circuit board to take up less height. YOu may need to get a longer ribbon to do it if you have th very short one.
I just opened up my xenarc 700tsv. I want to get rid of my buttons so i can fit my slimline rite under my screen. I need to remove those buttons but they are attached to the circuit board. How do i remove them??? Someone said desolder them but i need the circuit board to be removed also.....
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
You can really cut the board??? is that SAFE??
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
WTF? did you not notice the 'T' after the 'can'??????Originally Posted by Cheekz185
for god sake!
back away from the demel
肚子笑痛了
S60 Install
What do you guys use to cut circuit board off holding the buttons . How easy is this process?
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
are you ******* serious?Originally Posted by Cheekz185
READ: YOU CANNOT CUT THE CIRCUIT BOARD!
how many more damn times?
just lop the circuit board off right above the buttons, and when your screen stops working just send me all the parts![]()
肚子笑痛了
S60 Install
Every post on this thread has said you cant cut the circuit board - why do you keep thinking you can? can you cut your motherboard in half and expect it to work? no!
Oh my bad, i read that can instead of cant. SO how is tilting going to do me any good lol. I need to put a slim line cdrom where the buttons are!
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
