Results 1 to 3 of 3
Thread: Chopping up a heat sink
    Low Bitrate Speg's Avatar
    Mar 2004
    Is this as simple as I think it is? Chop up a heat sink into the sizes of the chips on the back of the monitor, stick them on, and have a fan blow air away or on them?
    This should keep the chips a bit cooler?
    OR am I out in the woods on this
    Maximum Bitrate Mad Ad's Avatar
    Oct 2004
    Hertfordshire UK
    should do - that is assuming you really need the cooling. I use individual ram heatsinks for any pcb chips i need to cool (come in a pack of 8, each one is the size of one individual ram chip)- i cut them in half for smaller chips like for videocard memory, or motherboard chips (had a dodgy network controller once, used to be the first thing to crash in the heat till i glued on of those on).
    They come with sticky pads though, no good at all- scrape them off, clean off all traces of glue and use arctic silver epoxy
    fantastic stuff.
    Mar 2004
    Reason being because I used to have the Lilliput plugged into the cig lighter. But day time I found the screen dimmed plus sometimes the picture went all scrambled when signal light was turned on or whatever. So I read and I figured 2 reason
    1: Not a constant 12V going to the screen
    2: Over heating.
    So last night I wired the Lilliput to the OPUS and it was definitly brighter! Me like But I am afraid now that heat "could" be a factor and with this constant higher power, I wouldn't want anything to over heat. So heat sinks on the chips and a fan to blow some air on them from the air vent to keep them cooler. That should be safe.
    Now, weather to buy or cut the processor one up :P
  1. m1-atx heat issue
    By neon_eddy in forum Power Supplies
    Last Post: 06-01-2005, 06:19 PM
  2. Voltage Regulator Constant Heat
    By phita23 in forum General Hardware Discussion
    Last Post: 02-21-2005, 01:18 AM
  3. Low profile AMD XP 2500 heat sink (no fan)
    By Arathranar in forum General Hardware Discussion
    Last Post: 01-08-2005, 05:15 PM
  4. To heat sink or not to heat sink ...
    By jnusaira in forum Newbie
    Last Post: 02-18-2004, 10:46 AM
  5. CPU Heat question: Which one would generate less heat?
    By kiztope in forum General Hardware Discussion
    Last Post: 02-12-2004, 03:14 AM
