First don't worry about D7, the data sent to the LCD is all in ascii, and the highest value you'll use is, z which is 122 or 01111010
Also when it's powered up, and there's no control software running, do you get black boxes on the screen, if you don't then it's going to be a problem with the contrast.
I hope that helps, a bit.
Rob
LinkBack URL
About LinkBacks
I got LCDisplayer to work, and LCDPRINT.EXE seems to work ok.
