Page 10 of 125 FirstFirst 123456789101112131415161718192060110 ... LastLast
Results 91 to 100 of 1244
Thread: lilliput in-dash 7"
  1. #91
    May 2005
    Toronto, ON
    Actually, I just noticed that in the specifications, the input voltage is 10.8-13.8V. Does this mean there is built in circuitry to regulate the voltage?
    I just want this screen to last. Pretty expensive investment!
  2. #92
    Jul 2005
    Quote Originally Posted by BikeBoy24
    Thanks for the quick replies.
    I'm curious, why is the fuse on the switched power yellow VCC? Shouldn't it be on the constant power red batt?
    Just to make sure, I connect my power supply wire to the red wire (BATT)? But that wouldn't be too good...the monitor would lose its settings everytime the computer shuts off wouldn't it?
    i never figured out why there is a fuse there makes me wonder too...but the batt wire shud b connected to a constant source of o power and the yellow one is the ignition (tells when to shut off/come on)
  3. #93
    Aug 2004
    ATL
    Quote Originally Posted by bran55
    Its the other way around. Yellow is constant and red is switched. Thats y yellow is fused. Also can u guys post some pics im really interested in this.
    One more ques: does it have and rca audio out? Thanks
  4. #94
    May 2005
    Toronto, ON
    Quote Originally Posted by bmoney03
    Yes, there are RCA audio outs. I will try to take some pics tomorrow before I install it.
    I don't think Yellow is constant (at least not on the lilliput harness). Even in the manual, it says Yellow is switched, and Red is constant. On a standard harness, it is the other way around.
    bran55, did you wire it up to an adapter? Did you just use the same colours? If so, Lilliput labeled the wires wrong.
  5. #95
    Aug 2004
    ATL
    WEll if u hook it up the other way around it just wont hold its memory. SO in that case just switch the wires around. Come to think of it i dont think it will even turn on if the wires are switched. But it would not make any sense for a switched wire to be fuses. U would want the constant to be fused. HMMM
  6. #96
    May 2005
    Toronto, ON
    That's true. It's not drawing any large current from the switched line. Unless, it uses the red wire as a battery backup, and draws the full current from the switched line. That would be weird. I guess I will have to try and find out.
  7. #97
    Jul 2005
    Touchpanel
    is anyone else having problems with the touch screen being flakey? Like getting it to work and then all of a sudden stop working? My computer see's it now as a "generic USB hub," when it used to see it as a touch screen? wtf is going on? any suggestions?
  8. #98
    Raw Wave kickercivic1's Avatar
    May 2003
    Florida
    reinstall the driver maybe?
  9. #99
    Maximum Bitrate MaleBuffy's Avatar
    Aug 2003
    Greece
    Whats wrong with the TS?
  10. #100
    Jul 2005
    7" In-dash
    Mine arrived on Saturday by UPS.
    Hooked it up last night Radio worked, VGA worked, TV worked...........motor will not close the screen. It stops it the horizontal position.
  1. 3rd Time's the Charm??? Mercury Cougar Dash Lilliput
    By antimatter in forum Fabrication
    Last Post: 08-07-2006, 01:21 PM
  2. FS: 7" In Dash Lilliput (Both Parts)
    By Avalerion in forum Classified Archive
    Last Post: 06-28-2006, 05:02 PM
  3. FS : Car pc (mini-itx full + lilliput in dash 7")
    By mph125 in forum Classified Archive
    Last Post: 03-18-2005, 08:48 AM
  4. Replies: 5
    Last Post: 04-01-2004, 05:37 AM
