I bloody well hope so, but it has to go back for there engineers to inspect it first, how long that takes is anybodies guess.Originally Posted by blackflux
So they are going to send you another unit (no homo)?
ø¤º°`°º¤ø
,¸¸,ø¤º°`°º¤ø,¸¸,
°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°
°`°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°` °`°
,¸¸,ø¤º°`°º¤ø,¸¸,
ø¤º°`°º¤ø
º°`°º
I think I will send mine back Friday. I don't even want this unit any more, I would like to get a full refund so I can buy something else. I wonder how the replacement unit's motor will operate this time around. On this one, it just sound like it was on its last leg. It moved extremely slow.
Has anyone else confirmed that 1 of the 4 speaker doesn't work for this unit?
ø¤º°`°º¤ø
,¸¸,ø¤º°`°º¤ø,¸¸,
,¸¸,ø¤º°`°º¤ø,¸¸,
ø¤º°`°º¤ø
º°`°º
Mine had only 3 of 4 speakers working, it didn't occur to me at the time that it could be wired up wrong..Has anyone else confirmed that 1 of the 4 speaker doesn't work for this unit?
"This bloke said to me you haven't got a clue about the damage the soap bar can do to you,
I tried to see things from his point of view but I couldn't fit my head up his arsehole too."
Originally Posted by 01blackbirdws6
i did mine in "video 1", it was kinda picky with me too but i cant remeber what i did to make it work
i have the unit hooked up to my speakers in my car. I didnt try testing each speaker but all of them seem to be working. I will check later today to verify this. But I have noticed that when i press the "loud" button that it seems to only make my front right speaker loud which is real odd.
so i checked and all are wired correctly. The only problem is when i press the loud button the entire right side is louder (mids and highs) while the bass of the left side is higher. The quality is alright, not the greatest, but then again it may be my speakers.
since my wiring seems to be correct this is how mine is on the lilliput harness:
FL+ gray
FL- gray/black
FR+ purple
FR- purple/black
RL+ green
RL- green/black
RR+ white
RR- white/black
The two NE's brown and the green/white are not connected to anything as is the Blue wire (POUR). The yellow is VCC (ignition), red is battery, two blacks are ground, orange is auto antenna
My harness is the same as yours apart from I also have a blue wire/POUROriginally Posted by 01blackbirdws6
Could that be something you can rectify in the menu maybe.Originally Posted by 01blackbirdws6
