Page 9 of 125 FirstFirst 1234567891011121314151617181959109 ... LastLast
Results 81 to 90 of 1244
Thread: lilliput in-dash 7"
  1. #81
    May 2005
    Toronto, ON
    I got mine earlier this week. I noticed that the harness has 2 ground wires? Why is this? Also, the instructions don't really describe the wiring that well. Can someone breakdown the different colours? I'm assuming they follow the standard, but I just want to make sure. Thanks.
  2. #82
    May 2005
    Toronto, ON
    Also, I haven't hooked it up yet. Does anyone know if there is an auto fold down feature when the ignition is turned off? My current car deck does something like that.
    I know with the other lilliput screens, you can program them to turn off automatically.
  3. #83
    Jul 2005
    U.K.
    Any one in the UK received one yet? I would like to know what the import charges cost.
  4. #84
    Raw Wave kickercivic1's Avatar
    May 2003
    Florida
    u just got email from that ebay seller. And mine should be in from 1-2 weeks. I didn't order it direct because i was affraid to d bank transfer.
  5. #85
    Jul 2005
    yes the screen does fold down after like 30seconds of turning the ignition off. Im not sure why they have two grounds. About what each wire is for did ur wires come labeled (ie front right = FR and rear left = RL) cause mine came with little stickers on them labeling them
  6. #86
    May 2005
    Toronto, ON
    Quote Originally Posted by bran55
    When you say it folds down after 30 seconds, is that with the screen connected to the unregulated 12V from the car?
    Yup, my wires came labeled too. Except for the orange one, that was not labeled. Normally, this is the dimmer wire.
    Not sure what the blue wire is for either. Normally, this is for the powered/ampped antenna. It is labeled "POUR"
    And which wire is for the remote turn on for my amps?
  7. #87
    May 2005
    Toronto, ON
    Did you also ground both the black wires? I'm thinking one is for the screen and the other is for the touch panel or radio. I wish I had the wiring diagram. I'm not sure whether I should ground the screen to my power supply or to the chasis.
  8. #88
    Jul 2005
    Quote Originally Posted by BikeBoy24
    Question 1 - it folds down when connected to the ignition wire and the permenant power source
    Question 2 - mine was labeled "NE" which in the intructions means not used
    Question 3 - yes the "POUR" is for a power antenna
    Question 4 - Im jus taping into the ignition wire for my remote wire for the amps
  9. #89
    Jul 2005
    yes i grounded both to my stock ground cable, but im not quite sure why there are two i jus say ground them ther there for a reason
  10. #90
    May 2005
    Toronto, ON
    Thanks for the quick replies.
    I'm curious, why is the fuse on the switched power yellow VCC? Shouldn't it be on the constant power red batt?
    Just to make sure, I connect my power supply wire to the red wire (BATT)? But that wouldn't be too good...the monitor would lose its settings everytime the computer shuts off wouldn't it?
  1. 3rd Time's the Charm??? Mercury Cougar Dash Lilliput
    By antimatter in forum Fabrication
    Last Post: 08-07-2006, 01:21 PM
  2. FS: 7" In Dash Lilliput (Both Parts)
    By Avalerion in forum Classified Archive
    Last Post: 06-28-2006, 05:02 PM
  3. FS : Car pc (mini-itx full + lilliput in dash 7")
    By mph125 in forum Classified Archive
    Last Post: 03-18-2005, 08:48 AM
  4. Replies: 5
    Last Post: 04-01-2004, 05:37 AM
