Results 1 to 2 of 2
Thread: Newbie Question.
    Jan 2002
    Question Newbie Question.
    So, I just came across this site today after pondering a car-puter setup for awhile.
    So, I'm confused by how involved the whole LCD screen thing is. Maybe I'm missing something but shouldn't I be able to use a simple LCD (like this ) and just hook it up like you would a normal monitor? If someone would explain why this is so complicated, I would appreciate it, as I've got to be missing something.
    Constant Bitrate lifeboat's Avatar
    Nov 2001
    Oregon Coast
    Well, you could, but there are some complications. That panel is way too big for a car, and it probably draws 30 Watts at least so you would need to run it from a AC-DC inverter. Other than that it would probably work. I'm not sure but I think some of those Dell panels require a Dell video card as well. Most folks with digital flat panels in the car are using small ones, and some of them require a special video card.
    Read through the back posts in the Display section, and use the Search link up at the top there ^.
    IEI PSB-4710, 1.5Ghz P4, 1GB RAM, 120GB HDD, Lilliput 8" TS, M2-ATX, BU-353,
    Ikey SL75 keyboard, BT Mini Keyboard, WLAN, EVDO, IC-PCR100 (AM/FM/VHF), HQCT, Centrafuse 1.6...
