Results 1 to 8 of 8
Thread: Xenarc TSV 700 Not switching inputs
    May 2005
    Muscat
    I have my PC installed and my game cube as well. I have removed the xenarc screen from its housing and i fitted it on a custom made bezel. I can not switch between different video inputs, witht he pc on the pc is displayed. the only time i was able to have the game cube viewable was when i connected it to AV/2 and had the screen set up as priority to AV/2. When i have it configured in this way i can not switch to the PC. Is there a problem with the monitor? could it be due to that i stripped the screen from its cover and had it attached to the custom made bezel?
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Lots of people strip their screen over here and they don't see to have that prob.
    Maybe you didn't plug the button the right way.... or your connection with teh main cable is failing??
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    May 2005
    Muscat
    i'll try it again, i doubt the connection is not secured, coz if i have the game cube on av/2 and i have av/2 as a priority it works.
    Nov 2004
    So is like you push the "s" button and it doesn't switch to the next video input???
    Nissan Aux-in MOD
    May 2005
    Muscat
    Quote Originally Posted by thanatos106
    yups, doesn't work with neither the S button or the remote.
    Nov 2004
    Did you relocate the buttons????
    I look that the whole controller is disconnect or something ...
    Edit:
    nevermind.....
    the other buttons work (vol+ vol- and etc)???
    Nissan Aux-in MOD
    May 2005
    Muscat
    all the other buttons work, on the remote and on the screen. except switching
    May 2005
    Muscat
    apparently you have to use the scan button on the remote in order to switch video inputs. tested it and it worked fine. the only thing not working is the touch screen, my car is at my friends garage so i'll try reloading the drivers again. i hope the touch pannel is not damaged.
  1. Xenarc 700 TSV and PCB board. Can they be separated?
    By justintime in forum LCD/Display
    Last Post: 06-05-2005, 07:58 PM
  2. For Sale: Xenarc 700 Tsv!!!!!!!!!!
    By autopilot747 in forum Classified Archive
    Last Post: 03-30-2005, 08:49 PM
  3. Why 1 VGA + 2 video inputs in xenarc TSV???
    By ramy_zohair in forum LCD/Display
    Last Post: 11-29-2004, 07:55 AM
  4. what does the back of the XENARC TSV look like?
    By Sporttracguy in forum LCD/Display
    Last Post: 11-23-2004, 01:50 PM
  5. Xenarc 700 TSV Serial
    By NUIpIsqo in forum Classified Archive
    Last Post: 09-13-2004, 06:59 PM
