Results 1 to 8 of 8
Thread: Epoxy or hot glue ribbon cables?
    Constant Bitrate UnsanePyro's Avatar
    May 2005
    RI
    I messed up the connector to the ribbon cable going to the control buttons on my lilliput.
    I jammed the ribbon cable into the slot using some paper to hold it temporarily. I would like to go with a more permanant aproach though.
    I am nervous about using epoxy, what if they don't sit quite right, and then don't work? Then I am screwed.
    I thought about using hot glue, but will that flow too much and get into the connectors? Or heat up durring use and flow down in?
    :: '97 2.5 TL :: CarPC 1.0: Complete :: CarPC 2.0: 95% ::
    Constant Bitrate accentsound's Avatar
    Jun 2005
    Jupiter!!!!!! FL.
    hot glue OK.
    Raw Wave tj!2k4's Avatar
    Oct 2004
    hmm.. i dunno about the lilliput and/or other peoples' setups, but i gotta say - my xenarc is getting REALLY hot in the summer here in NY, not burning hot, but it does get uncomfortable to leave my finger on the ts for more than a couple of seconds..
    i'd be really nervous if anything was hot-glued in there.
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    53
    i use velcro to hold one of my ribbon cables in place. The heavy duty kind. It gives me no problems
    FLAC evandude's Avatar
    Mar 2005
    Maine
    hot glue would be fine. it doesn't melt THAT easily. you can also buy high-temp hot glue if you are that worried.
    or if you want a similar solution without worrying about it melting, use silicone. I got a tube from home depot (its sold as like aquarium caulk or something) and i've used it for tons of similar things.
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
    May 2005
    RI
    I may just hot glue it, it doesn't sound like it is too much of an issue.
    Evan - The silicone you bought, is it in a squeeze tube, or a tube you put into a caulking gun? I work in a hardware store, but that is something I am still unsure about.
    Mar 2005
    Maine
    that's what I have. I bought that over the other various kinds of silicone because it is 100% silicone, no extra crap in it that might cause any problems with electronics.
    eegeek.net
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    dont epoxy it as if you break a cable you are *****ed!
  1. damn ribbon cables
    By JaxPt in forum LCD/Display
    Last Post: 03-07-2005, 11:16 AM
  2. Lilliput 8" ribbon cables?
    By therussman2002 in forum General Hardware Discussion
    Last Post: 12-24-2004, 09:17 AM
  3. Hot glue + xenarc inverter == unhappy.
    By fluffy2097 in forum LCD/Display
    Last Post: 07-28-2004, 09:08 PM
  4. Lilliput Ribbon Cables
    By Pokey in forum LCD/Display
    Last Post: 07-01-2004, 07:22 AM
  5. Hot glue in PCI slots
    By ppgt94 in forum General Hardware Discussion
    Last Post: 08-16-2001, 09:59 AM
