Results 1 to 4 of 4
Thread: Avoid Lilliput calibration on startup
    Jul 2005
    Hi!
    I have a Lilliput 7" Touchscreen, and every time i strart my computer it takes me into touchscreen calibration (4 points).
    Does anyone know how I can avoid this? Is it a driver setting for it?
    tnx
    noccy
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    update to the latest drivers and make sure you run the 25point calibration
    肚子笑痛了
    S60 Install
    Constant Bitrate UnsanePyro's Avatar
    May 2005
    RI
    When you install the drivers/touch kit thing, there is a box that you check that basically says run calibration at startup, which runs it every time. I accidently did it because I was in a hurry, and am also looking for the setting to turn it off.
    How do you run the 25 point calibration? I still have not been able to figure that out.
    :: '97 2.5 TL :: CarPC 1.0: Complete :: CarPC 2.0: 95% ::
    Jul 2005
    I have the latest drivers, and I was hoping not having to install them again...
    Maybe it's a registry key for it...I have found one in
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\Touchkit\
    It's called Start, but my car is not with me now, so I can't find out...
    noccy
  1. lilliput calibration failed??
    By nomorspam in forum LCD/Display
    Last Post: 06-30-2005, 10:41 AM
  2. Lilliput often needs calibration
    By cyrix^ in forum LCD/Display
    Last Post: 06-10-2005, 03:53 PM
  3. Replies: 6
    Last Post: 02-09-2005, 01:00 AM
  4. Replies: 11
    Last Post: 11-15-2004, 09:30 AM
  5. Lilliput 4-point and 25-point calibration?
    By chris in nh in forum LCD/Display
    Last Post: 06-20-2004, 02:16 AM
