Results 1 to 8 of 8
Thread: Telling if you've fried your display????
    Registered User MP3IAN by Ian Gregory's Avatar
    Jan 2002
    Wollongong, Australia
    Arrow Telling if you've fried your display????
    I have purchased a 40 X 4 LCD and i think i may have fried my KS0066 chips? Although i am not sure.
    The wiring is correct (now as the suppliers one was wrong hence possible fried display). Ireceive two rows of black squares (as i should) only i receive no response from the LCD no matter what application i use!
    Is this fried? or does the black squares indicate something?
    Mar 2001
    Cincinnati, Ohio
    Post
    Yep, I've gone through 4 lcds with bad wiring diagrams, before I just broke down and bought one from arby.
    Clarion 200watt head unit w/ Aux in.
    Kicker 800watt 4 channel amp
    In a 96 Grand Prix SE.
    Jan 2002
    Arrow
    Was that a "Yep it's Fried!!!!" or simply a "yep, ive fried..."????
    Rob
    Rob is offline
    Maximum Bitrate Rob's Avatar
    Aug 2001
    Missing In Action
    Post
    From experiance, if you've got the black squres, it's not fried, nomally they're fient with clear line thru them if they're fried, trust me I've fried a few, and it takes a lot of work to cook them
    Double check you've got the contrast correct, also check the software is running as you want it to.
    Rob
    And you say people actually pay money for M$ Windows?
    www.mp3mini.co.uk (Does what it says on the URL) www.openclassic.co.uk (The new car, with zero rust!) www.rob-web.co.uk (My other site)
    Total re-design underway: on the whole progress is very slow as the car is taking up too much time :)
    FLAC Mastero's Avatar
    Aug 2001
    India
    Post
    hey buddy ...i have fried the KS0066 chip in a most stupid way ... Just by connting the Backlit power to the driver .. BOOM the KS0066 is gone in a matter of 1/2 second.. but to my luck the manufacturer of that 40x4 LCD was a Local company .. so i went to their work and made a big noise and they said some one connected the cable wrong !!
    "oops! i did it again"
    So i guess .. you know wat i am talking about
    Jan 2002
    Post
    Heres the problem: I have a Powertip 4X40 LCD with two KS0066 chips and four KS0063 (i think) chips on it. I am absolutely positive that the wiring is right and the contrast is correct. The problem was that the manufacturer had sent me the pinout for a 4X20 char LCD and not the 4X40. I connected (stupid for not realising)the LCD as the manufacturer had reccommended and then one of the chips got really hot. I then realised and rewired it. It seems to startup normally like any normal display only, LCDprint.exe adn any other plugin within winamp doesn't work.
    I have wired it using the standard 4X40 wiring diagram as (the same as the seiko ones are wired.)
    If it isn't fried, then what is the problem. I can see no signs of burnt out tracks or chips.
    Please help!
    Aug 2001
    India
    Post
    buddy these are very sensitive chips they will not show sign of burnt up .....
    Ok tell me one thing when you fist connected the LCD did the backlit go on?
    if not Buddy u got a dead one in your hand ...
    if your lucky check the voltage required for the LCD once again .... sometime its 5 or 12 ...
    Mastero
    Jan 2002
    Post
    Unfortunately, no backlight!
