Results 1 to 8 of 8
Thread: Audiovox LCM640CS: 6.4 Display
    Jul 2000
    Question Audiovox LCM640CS: 6.4 Display
    Does anyone know anything about this display:
    http://cgi.ebay.com/ebaymotors/aw-cg...ndexURL=0&rd=1
    I called audiovox about it, and they confirmed that it is 640x480. How can that be true if it has composite in? I thought NTSC was limited to tv resolutions (320x234, or widescreen 480x234).
    Anyone have any idea as to what the truth may be here?
    Thanks.
    TP
    D2
    D2 is offline
    Oct 2001
    San Carlos, CA
    Post
    I don't know anything about that display, but NTSC whether it be composite, Y/C, or RGB, has a "standard" video resolution of about 640Hx480V viewable pixels for a square-pixel, 4x3 aspect-ratio display. The 320x234 represents the pixel structure on other LCD screens that WILL display the 640x480 video "standard" by stuffing all those video pixels into a smaller number of displayed pixels. A LCD display with 640x480 screen pixels will look better than a LCD display with 320x234 screen pixels.
    I hope the way I said this makes sense.
    Still workin' on it.
    FUBA Homepage
    Jul 2000
    Post
    In case anyone is interested I got this screen and took it apart.
    It has this LCD in it: Prime View P64CN1 http://www.mansky.co.uk/pvi.html http://www.unitronic.de/Hersteller/PVI/pro6.4av.htm
    It is (according to these links and NOT according to the audiovox manual that came with the screen which says it is 640X480) 320 X RGB X 234. So the manual from audiovox is not right.
    Both of those links above say that this is has NTSC/PAL/VGA inputs and in taking it apart I found that it has connections for rgb+hsync+vsync. Isn't this what makes up a VGA signal? Or is this expecting an RGB NTSC signal?
    Here is a picture of the connections I am talking about:
    Dec 2001
    Post
    Toyota P refect,
    I've got the same screen, and trying to figure the same thing out. Im just going to hook up a vga cable and see what happens. But let me know if you find anything else.
    Thanks,
    SD
    Dec 2001
    Post
    Tried hooking it up. I got a picture but could not get it to sync. I tried every refresh rate/sync width/front porch/back porch etc.. that I could think of but could never get a stable picture. Anybody have any ideas???
    SD
    Dec 2001
    Post
    Just a bump here... I would really like to get vga input on this, anybody got any ideas???
    Thanks,
    Dave
    Jul 2000
    Post
    Superdave,
    Just saw this posted elsewhere:
    http://home1.gte.net/bs/sharp2.html
    Any help?
    May 2002
    I've just bought a screen like this too.. have anyone tried this?
