If you have room on your dash or are willing to operate, the easiest way to get it the correct way on your windshield is to use a mirror in between to flip the image. VFD is definitely the only way to go if you want a reasonably bright image, unless your LCD's backlight is damn bright. The ability to do simple graphics depends entirely on your LCD's controller firmware. Most won't let you do much beyond 8 or 16 custom characters. If you really want simple graphics, try CrystalFontz' 634 Intelligent Serial Display -- it's basically a graphical display separated into 4 lines, but you're going to have to do some programming, but if you can already code, it's pretty easy. After that, you're going to have to use a graphical display. Matrix Orbital's graphic displays aren't too bad to code for, comparatively speaking.
LinkBack URL
About LinkBacks
