Page 33 of 38 FirstFirst ... 23242526272829303132333435363738 LastLast
Results 321 to 330 of 375
Thread: SP-716,DWW-700M,MTS12000 and etc
  1. #321
    Newbie Imy01's Avatar
    Jul 2006
    For those of you who are interested...
    Just updating since my last post. I've had the SP-716 in the car for a month now with ALMOST no problems...I had one incident where I think I sent it into TV tuner auto-programming mode and it wouldn't respond to input for about 5 solid minutes...But everything's been working fine since. I'm surprised, since it is exposed to healthy doses of bass on a daily basis...We'll see how long it continues to work as well as it is.
  2. #322
    Feb 2005
    El Paso, TX
  3. #323
    Aug 2006
    I did the exact same thing and got the same response :-( Yuki668 WHERE ARE YOU!
  4. #324
    Sep 2006
    i got my screen. so is this tv antenna plug a standard automotive tv plug? or do i need to do some modification? i have never seen a coaxial plug that looks like this.
  5. #325
    Aug 2006
    when did you order it and who did you order it from? You didn't order it from Yuki668 did you?
  6. #326
    Constant Bitrate AWDNUT's Avatar
    Aug 2005
    Canada
    I got an adapter from radio shack for $8 (PAL -> NTSC) but I have't tried to make it fit cause I already have depth issues.
  7. #327
    Feb 2004
    Well I got this screen about 4 months ago and I think it's starting to die on me. I'm starting to get alot of random pixels flashing. Can't see it when the screen is black but on just about any other colour it's noticable. The edges of words are the most noticeable. Using Iguidance, I noticed the grey streets are filled with "sparkling green dots". Does this mean my VGA controller is on the way out? Anyone seen this kinda problem before on other screens? This started to happen all of a sudden. I didn't make any changes to the system so I don't think it's interference.
  8. #328
    Variable Bitrate walstib's Avatar
    Jul 2005
    Atlanta, GA
    Quote Originally Posted by AWDNUT View Post
    I bought the same adapter and tried using rabbit ears before it was mounted in the car. Very poor reception so I didn't even try it in the car.
    Carputer Project Status:
    0% - Mobo died on 2/17/08
    Check out the worklog for my '01 Pathfinder.
  9. #329
    Jun 2006
    Breaking Screen?
    HI. Bought mine from yuki and worked great for about a month then one day I turned it on and it showed vertical lines and then to a blank white screen. If I turn it on and off a few times it comes back and works. No luck contacting AI, does this sound like it might be the ribbon cable? Can it be replaced? Easily? Have had no issues with touch screen or motor functions. Anyone have any ideas about what is going bad? Thanks
  10. #330
    Oct 2006
    Hy, bought mine here in Germany.
    My only Problem with this screen is that it does not Remember the Clock or the Angle of the Screen.
