Results 1 to 10 of 12
Thread: can a touchscreen be installed upside-down?
    Variable Bitrate shrinkydinx's Avatar
    May 2005
    Obviously is can be, but I need to know if, when I use software to rotate the screen 180" Will the touchscreen aspect also be rotated, or will touching the top left act as a click at the bottom right?
    I asked this a long long time ago but no one could give me a definite answer...
    Variable Bitrate Moneyfink's Avatar
    Feb 2005
    S Ohio
    I would think that If you leave the touchscreen overlay on the monitor the two parts would move in sync. If you performed a calibration after the flip, I think that a it would touch where you want it to everytime. the important parts are performing the calibration and leaving the overlay in the same position
    My OLD carputer page
    My NEW carPC
    Via Epia M10000, 512 PC2100, Opus 150, 8" lilly touch, 320 GB 7200 WD Caviar
    Variable Bitrate Curly_cat's Avatar
    Jun 2004
    Ipswich, UK
    The touchscreen doesn't "know" which way up the display is, it just knows where you have touched it.
    run the calibration tool once you have flipped the display image.
    : Jetway J7F2 1.5Ghz Mainboard : Cubid 3688 : CarNetix CNX-P1260 :
    : Netgear 802.11g PCMCIA : 2 x LinITX 7" Screens :
    : BU353 USB GPS Mouse : Panasonic UJ845 DVDRW :
    May 2005
    Well, I haven't bought the screen yet, and I need to know the answer to the question so I can know what my options are... Anyone want to try and calibrate their screen flipped 180" and tell me if that works?
    Jun 2005
    Phoenix, AZ
    It will work, thats what the calibration does. Sets up the orientation.
    Scott
    May 2005
    Quote Originally Posted by spdyscotty
    Scott
    i would assume so, but id rather not spend the $500 and take the chance that the designers were too lazy to allow the calibration to be rotated 180 degrees...
    want to try calibrating your screen 180 degrees for me?
    Newbie etown's Avatar
    Jun 2005
    Shilo MB, Canada
    Quote Originally Posted by jamphat
    It works. I ran mine upside down for the better part of a month.
    Jun 2004
    The North, Manchester
    how do you flip the image??
    Variable Bitrate kamikaze2112's Avatar
    Feb 2005
    Barrie Ontario
    Quote Originally Posted by OriginalNick2
    There's software you can get to do it. Most on-board intel graphics drivers have this ability, and so do most nvidia and ati drivers.
    Jul 2004
    Flipped mine too for a couple of months. egalax TS controller worked fine after calibration. Via has an option in their advanced display configuration screen to rotate the display 90 or 180 deg. I'm pretty sure ati drivers have the ability to rotate the display. others probably do to.
    Carputer installed!!!
    Nlited XP+Minlogon, EpiaM10k, 512mb, Seagate 40 gig 2.5" HD, FM Dlink usb radio, DWL122 USB Wifi, XMD1000 tuner, PT5071 6 amp regulator, Xenarc 700TSV, and 1 ikea key box.
  1. messed up touchscreen
    By chavoush in forum Input Devices
    Last Post: 07-10-2004, 11:54 PM
  2. Lilliput touchscreen woes/probs
    By Leddy in forum Input Devices
    Last Post: 05-15-2004, 09:42 PM
  3. sunvisor LCDs w/ touchscreen
    By FiSKARZ in forum LCD/Display
    Last Post: 01-08-2004, 01:38 AM
  4. touchscreen kits
    By darkmiasma in forum Input Devices
    Last Post: 12-17-2003, 05:13 PM
  5. touchscreen woes.
    By ares in forum Input Devices
    Last Post: 03-19-2003, 12:11 AM
