5" replacement bulb?
Im looking for a replacement for my tft lcd backlight. This is the 5" flip screen sold on parts express. I am wondering if anyone is familiar with replacing this (im talking about the whole white tray with the bulb and everything). If so where did you get it and how much. Im having trouble with a short in mine. Like when i have everything taken apart it works fine but once everything goes together it shorts out part of the bulb.
if it shorts out when the case is on, then try putting a piece of paper in between the case and the board or use a spacer (or something)... b/c if the problem only occurs with the case on then changing the bulb may not be much help...
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
