Results 1 to 7 of 7
Thread: lilliput usb device not recognized!!!!
    Jun 2005
    So i installed the touchkit software, but when i plug in the usb cable, i get a device not recognized notice in windows xp pro w/sp2.
    I tried manually installing the drivers by going to device manager, update drivers > then manually pointing to the touchscreen.inf files in the driver directory.
    I get an error message saying "the file contains no data about your hardware ect..."
    its a 629 model, brand new, everything else seems to be working fine, i checked the din connector, no bent pins there, all the connectors are tight.
    It seems like it would be a software issue but i really have no idea at this point.
    HELLPP!!!
    Mike
    Jun 2004
    Central California
    I have never experienced the same problem so this is just an idea: where is the USB plug is connected to? If it's connected to USB hub, is it properly powered?
    EPIA Nehemiah M10k, M1-ATX, 20GB 4200 RPM 2.5", 256MB RAM, Win XP Home, Gyration RF Keyboard & Mouse, Zoltrix Nightingale Optical 4.1 PCI Sound Card, Lilliput 619GL-70NP, XM-PCR w/ optical upgrade, Garmin GPS-25LVS, Microsoft MN-710 USB Wireless NIC
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    i'd start by deleting all of your USB drivers, and letting windows pick them back up. If you've just installed service pack 2, its a common problem that your USB devices will act up. Secondly once you have reinstalled your usb driver (might need the motherboard CD, or drivers from your mobo's website), install the touchkit drivers. I believe xenarc has one on their website....it will work with the lilliput.
    PC Components:
    My work log
    Jun 2005
    screen
    I've successfully installed the touchkit software, how do i install the drivers?
    If i go to the file that i've extracted, there is a setup icon, that installs the touchkit software. But how do i install the drivers. The way that i tried to do it should work correct?
    MIke
    Jun 2005
    b
    bump1
    Maximum Bitrate Mad Ad's Avatar
    Oct 2004
    Hertfordshire UK
    im sorry to say that the only way I managed to resolve my lilliput usb device not recognized problems was to send it back to my supplier and get a non lilliput motorised screen instead.
    Jun 2005
    din
    I think it may be a problem with a faulty din connector, i sqeezed mine tight and it recognized the device for a second, but i couldnt get it to work again after that. Im trying to source a new cable
    Mike
  1. Replies: 15
    Last Post: 05-04-2006, 05:53 PM
  2. Replies: 6
    Last Post: 01-21-2005, 03:12 PM
  3. Lilliput USB Circuit Board...
    By gleinz in forum LCD/Display
    Last Post: 01-18-2005, 05:09 PM
  4. LILLIPUT Solder the USB cable etc..
    By darthvinh in forum LCD/Display
    Last Post: 06-17-2004, 05:48 PM
  5. Lilliput USB not recognized anymore
    By SFiorito in forum LCD/Display
    Last Post: 05-31-2004, 12:09 PM
