Results 1 to 10 of 12
Thread: motorized 7 inch vertical eject options
    Aug 2005
    Hi, I'm after a top quality 7 inch, VGA, touchscreen monitor that has a motorized eject mechanism. However, the unit must be programmable so that it just ejects out and doesn't flip back. This is so I can mount it vertically in the dash and have it pop up out of the top.
    I've been looking round for ages but haven't come across one that meets all those requirements. Any suggestions would be gratefully appreciated.
    FLAC ukchris's Avatar
    Nov 2003
    Massachusetts
    I think a screen like my DWW-700M should do it, it remembers where it was last set.
    Aug 2005
    Thanks for the prompt reply. So it remembers where you last set it. Can you set it to flip 0 degrees after popping out then?
    thanks
    Oct 2004
    ukchris how do you like the screen? what video card are you using and at what resolution? I am looking at my options for screens
    Aug 2005
    ukchris, can it be set to not flip (i.e. at 0 degrees). Thanks
    Aug 2005
    can anyone please provide an answer to this question?
    Constant Bitrate elmo's Avatar
    Mar 2005
    Staffordshire, UK
    surely with a motorised system there would be a seperate motor for turning the screen to a 90 degree angle, cant you just get in the disable it, it may be as simple as removing a belt, that way you can put it back on if you ever wanted to
    www.streetrace.co.uk - The UK's best modified car club (With lots of 16/17/18 year olds for scouse to abuse)
    Jun 2005
    The Lilliput 7inch motorized remebers its position so you can set it at 90
    and it will go back to that position when it shuts down
    Aug 2005
    Quote Originally Posted by elmo
    Its just that when I pay so much for a screen I don't want to have to open it up and have to 'break' it. Also, surely it would be cheaper to find one that just opened and closed automatically but you lifted up manually?
    Constant Bitrate Cravex7's Avatar
    Jul 2005
    Salisbury, England
    Avoid that screen like the plague, you can read about peoples problems with it in the link below but to cut a long story short most of them have broken within days.
    lilliput in-dash 7"
    "This bloke said to me you haven't got a clue about the damage the soap bar can do to you,
    I tried to see things from his point of view but I couldn't fit my head up his arsehole too."
  1. Replies: 30
    Last Post: 07-28-2010, 11:14 PM
  2. different motorized options already?
    By RoyN in forum LCD/Display
    Last Post: 04-18-2005, 08:27 PM
  3. 3/4 inch Plexi Glass/Diamond Plate Amp Box
    By lostreception in forum Fabrication
    Last Post: 03-20-2005, 09:15 PM
  4. build XENARC 7 inch into motorized DIN ?
    By BOND007BE in forum LCD/Display
    Last Post: 09-23-2003, 03:43 PM
