Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: overhead lcd
  1. #11
    Live and Kickin'
    Arby's Avatar
    Dec 2000
    Houston
    Post
    I think running the +12 and ground from the PC is the best thing to do
  2. #12
    Jan 2001
    San Francisco, CA, USA
    Post
    Have you tried running the screen to a separate battery just for testing purposes. Ground this battery to the frame, and connect the postive battery post to only the screen. This way you have a 12.6 volt source, and should not get any of the noise or stepped up voltage from the charging system. This way you'd know if you were really looking at a problem with the connection to the car or something else. Also, how much heat is the headlamp giving off? Could there be a thermal triggered shut off for the screen? It reaches a certain temperature, and turns itself off. Also what is the charging voltage of your car? Hopefully 13.6 - 14.6vdc. If above 14.6 volts you could simply have a bad voltage regulator for your alternator. Good Luck.
  3. #13
    May 2001
    Thumbs up
    Thanks for the help. I got I to work using the 12v from the psu. I went for a 1/2 hour drive and it never turned off.
