Results 11 to 20 of 23
Thread: Electrical Engineers please help
  1. #11
    Mar 2003
    Beijing, China
    Quote Originally Posted by khan1369
    Yeah, everyone can buy a controller card. They only cost a few hundred....
    I assume you live in the US... you know on the other side of the Earth, where I live, it also costs a few hundred... Chinese Yuan...
    the conversion rate is approximately 1:8, so you do the math...
    I actually bought my LCD kit (panel+controller card) for 570 Yuan shipped. (70 USD)
    Project:Carputer
    [====================] 100% Completed, done, finished!
    Car: 2003 VW GOL
    Motherboard: VIA M10000
    PSU: ITPS + 12VDCATX + 7.4ah 12V battery
    Monitor: 7' LCD with Video, S-video, and VGA
    GPS: deluo USB
  2. #12
    Jul 2005
    BlueVisor, where did you order your kit from? $70 isn't too bad. Can I get it here in US?
  3. #13
    Jul 2005
    Here is a thought.. All the chips needed for the controller card are inbedded in a laptop motherboard right? Why can't a a new board be manufactured from the stuff on the motherboard? Also, I have heard that there are some laptops that have removeable video cards but they are an entirely different bus system so you can just mount it to an ATX motherboard. Can't some sort of adapter be made? And anyone know of a laptop with a removeable video card?
    And what about the single chip lcd controllers? What can be done with those?
    http://www.genesis-microchip.com/products/gm5020.html
    http://www.nuhorizons.com/products/N...q19/sharp.html
    http://www.semiconductors.philips.co...7/75013197.pdf
  4. #14
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    You guys are right. It is a tremendously difficult task. And no, I will probably not be able to do it. But that does not mean I am going to give up looking for a solution. Hacks area dime a dozen. There has to be a way to hack even this.
    LCDs can certainly be hacked. I've seen an LCD hack that drove the panel directly from a analogue VGA port (plus perhaps a few discrete components, I don't quite remember). The system was put into a very perticular bit depth and refresh rate, and the guy only got like 6 bit color, but it did work. I don't know if it's possible to do something like that for any, or even many, LCDs, but hey.
  5. #15
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Disk drives are kind of expensive. Why don't you see if you can magnetize something like a Beyblade and assemble the controller chips and components from stock. It ought to save you a lot of money vs. buying a microdrive.
    Want to:
  6. #16
    Registered User
    May 2003
    This will tell you roughly what is needed to build one >>>
    http://www.mite.cz/crt2lcdfiles/TD-CRTtoLCD-1-TC.pdf
    The controller is a Genesis GMZAN1, if you can atleast find the datasheet for that with a basic reference design then you are already 1 step out of a 1000 needed.
  7. #17
    Oct 2004
    NY
    Quote Originally Posted by Chris31
    I wanna see someone build that here for under $100
  8. #18
    Low Bitrate 99bravada's Avatar
    Dec 2003
    Fort Lauderdale
    I had an old Toshiba Satellite 410 I think was the model number. There was a removeable daughter board which was the video card. I've heard of people making PCI cards based on these cards, which have a CHiPS and Technologies microcontroller on board. Not sure what would be involved in making one of these into PCI, but I'm sure it could be done by the hobbiest with a little R&D.
    Current:
    2011 Black Jeep Wrangler Unlimited Rubicon | 20" KMC Rockstars | 35" Nitto Mud Grapplers | Rugged Ridge XHD Front Bumper | Kicker KX350.4 amp
  9. #19
    Jul 2005
    Thanks bravada, that was the kind of post I was looking for. I will look into it.
  10. #20
    Registered User
    May 2003
    Quote Originally Posted by turbocad6
    But guess what? I always wanted to design, build my own jet engine at home, using hacksaw, a drill and a used spray can. But then I was only 9 yo then
    It is probably possible to build one for under $100 only if the design is already laid out, you have access to PCB, chip programmers, SMD workstation and test equipments.
    Getting hold of the parts can be a problem already, some can only be bought in 1,000pcs.
    Designing it yourself with no knowledge what so ever? and without access to equipments? hmm no I dont think it ever materialise. Better off finding something to mod.
    Anyone trying a motherboard for under $50 then?
  1. Replies: 21
    Last Post: 05-24-2005, 04:41 AM
  2. Replies: 2
    Last Post: 10-28-2004, 02:52 PM
  3. Replies: 6
    Last Post: 09-30-2004, 05:38 AM
  4. need some major electrical help=calling all engineers
    By ssa_whiskey in forum General Hardware Discussion
    Last Post: 02-15-2004, 12:39 PM
  5. Replies: 13
    Last Post: 12-12-2003, 02:26 PM
