it seems you don't have a vga connection.. too bad!
try to connect it with composite/ s-video.
You will buy a lilliput WITH VGA soon mate!
i have got a Lilliput 7 inch wide screen ldc tft
I'm gonna start with a carputer and I want to know how I can connect this screen with my home computer to test it
specs...
Model Number. 319GL-70NP
Key Specifications/Special Features:
Screen size: 7 inches (diagonal)
Ratio: 16:9 wide TFT screen
Optional 4 display modes: 4:3<-->16:9 <-->16:9 Zoom<-->4:3 For CCTV
Resolution (H x V): 1440 x 234 = 336,960 pixels
Color configuration: RGB stripe
Video system: PAL/NTSC/SECAM auto conversion
2 Video inputs plus 1 Audio input
IR remote control
Full function OSD control (Multi-language)
Audio output: Speaker built-in & earphone jack
Video input signal: 1.0Vp-p, composite video
Reversible screen: X-turn (mirror picture) & Y-turn (flip-down picture) available
High resolution and no radiation (better for eyes’ protection)
DVD/VCD/Security system/Navigation system compatible
(Rear view camera connectible)
Mount type: Dash board
Power input: DC 12V
Power consumption: 9.5W
Dimension: 194×122×26(mm)(W x D x H)
greetz
I've only got this cable![]()
Does you system have a composite input for the video card??
my home pc not.
But I'm gonna buy a pc that I want to build in into the car., then I need to look of the pc got a composite input.
How does it look like?
I'm a dutch, that's why I dont understand it.
via M10000 has a composite out port, ive no idea if it works.
but you should really get a VGA screen
And when I buy this cable, will it work then?
I'v got that tft for about 3 weeks, I first want to get a dvd player but now I'm gonna start with a carputer.
So I have bought this tft for nothing!
It does in my MII12Kvia M10000 has a composite out port, ive no idea if it works
Not just the cable on its own, you need a screen with the D-SUB connection (for VGA) on it that that cable has.Originally Posted by HoRiZoN
Also you really need a touchscreen too- its possible to use without one but its much better with.
