Ok, well I am gonna assume that you only have the composite hooked up and not the vga. On my setup I had to put a 75 ohm resistor(1/4 watt is fine) on my composite output(shorted across the composite output with the monitor still hooked up) so it would know something was hooked up to it. My video monitor didn't have enough internal resistance for the video card to pick up. I didn't notice a signal difference after I removed the resistor so its ok the leave it in(that way it will always work when you have to bootup). I hope this helped.
Steve
My setup
LinkBack URL
About LinkBacks
