Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: polarizing film to switch dark characters to light and background to to dark
  1. #11
    Oms
    Oms is offline
    May 2000
    The Netherlands
    Post
    Arby - I don't get it. Can you please explain in a little more detail. Why would redoing the polarizing on the back help? Redoing, how exactly? And why would it be more difficult than the front?
    AFAIK, a normal LCD has its polarizers at right angles to each other. When you invert it, they become parallel. So I don't understand what you mean by "redoing the back".
    Custom Linux system on an '89 VW GTI 16V Edition One
    Jogdial volume control, Sony joystick, IR remote...
    Used to be the fastest Linux on the road, until all these NOS types came along...
  2. #12
    Live and Kickin'
    Arby's Avatar
    Dec 2000
    Houston
    Post
    http://mp3box.2y.net/temp/polarizingdiagram.jpg
    The reason I said the back one is harder is that you have to be careful to not break off the conductive strips. They aren't on there that great.
    Here's a picture of a LCD I did that way, and the contrast is fine in the daylight
    http://csg.2y.net/mp3box/temp/jesse/06.jpg
  3. #13
    Apr 2000
    Austin,Tx.
    Post
    Arby, I noticed on your diagram that you stated that the rear piece of porazing film had to be vertically polarized, but not quite, because lcd twists the polarization slightly. Does it matter which way to rotate the film? And if it does matter, how do you figure out which way to rotate it without putting the display back together with a piece of film in the back?
  4. #14
    Live and Kickin'
    Arby's Avatar
    Dec 2000
    Houston
    Post
    Before you cut it, slide a small piece in there, and rotate it until you get the best contrast. Then cut the full piece in the same direction.
  5. #15
    Apr 2000
    Austin,Tx.
    Post
    Thanks Arby,
    I was actually just hoping there was a way to figure it out without putting the LCD back together.
  6. #16
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    Post
    I gave that a shot and just couldn't get it to look as nice as yours, Arby...
    All a piece behind the lcd did was make it dimmer. I tried two pieces in front of the lcd and, after much turning, could get the background black, but the text was almost unreadable...
    What's your secret?
    http://www.jeepmp3.com/
    CarPC Stolen. Starting over.
    Ne1 recognize the avatar?
  7. #17
    Live and Kickin'
    Arby's Avatar
    Dec 2000
    Houston
    Post
    Are you using the film from www.polarization.com ?
  8. #18
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    Post
    Yup.
    Matrix Orbital LCD (Though I doubt the display differs from any other lcd)
  9. #19
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    Post
    I think I know why it doesn't work for me...
    You guys aren't using MO displays, I'll bet.
    Your displays have some degree of refleciveness to the backing (transflector). This allows light to pass through the display and back out again. The polarizer behind the lcd would be effective.
    My MO display must not have a reflective surface (transmissive), all light you see from the display is provided by the backlight... This probably renders a rear polarizer ineffective.
    I don't know. What do you think?
    This site has lots of info on LCD's -
    http://www.densitron.com/product/lcd...ulcdglass.html
