Results 1 to 10 of 14
Thread: messed with the lilliput -- now "no VGA signal" :(
    Nov 2004
    NY tri-state
    Damnit...
    I took one of my lilliputs apart yesterday to mount it on the non-motorized single DIN housing, and now I'm getting a "no VGA signal" message all the time.
    I took the easier approach... instead of soldering directly to the board, I clipped the connectors going to the board, clipped the lilliput (10-pin) cable and spliced everything together. Really simple (or so I thought) since I don't have to remember what cable goes to what pin... just to match the colors...
    But anyway... I spliced everything up (vga and touchscreen) and while the touchscreen works perfectly, all I get on the screen is a "no VGA signal" message. I made sure there are no shorts, and the contacts are good... and I'm obviously matching the cables right (well, unless I'm color blind ).
    Any ideas as to what else I can check? I figured it was one of the wires, but I'm pretty sure everything is connected properly (including the ribbon cable).
    Nov 2004
    NY tri-state
    nobody?
    Why would the screen fail to see a vga signal if the cables/connectors are right? Is there anywhere else that I can look?
    I didn't hook up the video 1/2 inputs, but I guess I'll try them now and see if it's just the vga or if the whole screen is fubar.
    Maximum Bitrate tolisn's Avatar
    Dec 2003
    Greece
    Quote Originally Posted by viguera
    nobody?
    Well I did exactly the same thing and everything is OK.
    The only thing I can think of is that when you matched the color of the wires you conected the purple to the blue and vise versa. I'm telling you this because these two colors are so close to each other you can easily mistake one for the other, (I know I did).
    The road is long but we are getting there.
    Nov 2004
    NY tri-state
    Quote Originally Posted by tolisn
    Well I'd have to be CRAZY color blind, but I'll try it and see... I did it a few times and checked all the colors though, so I don't think that's it.
    BUT on a sadder note... I took everything apart and hooked up the rca (video 1/2) cable back on to the connector on the side, and I hooked it up to a video source and changed the input, and I'm getting "no cvideo 1" (or 2, or whatever). So I doubt it's the vga cable now... otherwise the vga wouldn't work but the video 1 / 2 would...
    So... I'm guessing it's some loose connector or broken trace or something... the ribbon cable is perfect (got the extended one from Armen) so it's gotta be something else, but I'll be damned if I know what...
    Maximum Bitrate Zebelkhan's Avatar
    Dec 2004
    Bay Area, CA
    It sounds like the ribbon cable.
    I just spend a day and half with my lilliput (what a way to spend the weekend) because when I took it apart for a dash install and put it back together I either had "no VGA signal" or strange vertical multicolor lines running up and down, or the Jurasic Park logo. I also noticed that at times (especially when I had the "no VGA" signal, the button that switched between VGA and Video 1 and 2 did not work. After tinkering for a day and half, and breaking a few pieces on the board and resoldering back, it was the ribbon cable going to the button board that was not seated properly. After a million trys, I got lucky and got it right and now it works fine...
    Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
    Sep 2003
    Finland
    Damnit...
    I did the same to my lilliput with 9 pin connector and I had same kind problem as you. So I checked that original connector, and the wire colors didnt match. (both connectors had same colored wires, but in different pin numbers.)
    Nov 2004
    NY tri-state
    Quote Originally Posted by vvog
    WTF!
    Oh that's some BS right there... thanks, now I gotta break out the multimeter and see if purple on one end is blue on the other or some crazy crap like that...
    Nov 2004
    NY tri-state
    Quote Originally Posted by Zebelkhan
    Thanks for the tip, but I'm not sure if that's my problem... I hooked up the original button PCB and ribbon cable last night trying to see if it was the VGA, RCA or both, and with the buttons working perfectly (used them to switch to video 1 / 2) and a working external RCA source, it did the same thing.
    Hopefully it's something simple (stupid) like the colors not matching on both ends of the connector, and I can just find the right pinout and call it a day.
    Thanks anyway though...
    Dec 2004
    Bay Area, CA
    I still say move the cable on the button pcb to one extreme end and then little bit at a time move it towards the other end. That is what I ended up doing. I got all the above image scenarios until I found the right spot. I guess the cable end was worn out too much and I had a lot of room to cover...
    Nov 2004
    NY tri-state
    damnit... the screen won't turn on now. Is there a fuse I can check? I know my power source is good and using another controller I can power up the tubes, but the screen I'm working on doesn't work...
  1. WTB: Broken Lilliput or VGA Controller
    By planar in forum Classified Archive
    Last Post: 04-23-2005, 09:30 PM
  2. Lilliput VGA controller or lcd screen??
    By Mush in forum LCD/Display
    Last Post: 03-22-2005, 04:54 PM
  3. Lilliput 7" VGA touch screen cables
    By jeeve76 in forum LCD/Display
    Last Post: 03-03-2005, 02:11 AM
  4. Replies: 3
    Last Post: 10-04-2004, 06:13 PM
  5. Replies: 0
    Last Post: 09-27-2004, 08:07 AM
