Results 1 to 10 of 11
Thread: in dash LCD question,.
    moahdib's Avatar
    Jul 2000
    Post in dash LCD question,.
    I know some of you guys have in dash LCD's from clarion pioneer etc etc....
    Most LCD's are sunlight visible hence they are very bright at night. Can you adjust the LCd so it's not too bright at night and won't attract attention from cops or people driving next to you?
    I have a removeable 5.6" LCD and it's so bright that I had to tint a piece of glass on both sides with window tint ( 5% visibility). Only then the brightness is at a normal brightness for night time driving. I believe the brightness control on my LCD is messed up...doesn't go all the way down to very dark.
    04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
    Fast car, fast PC. ;)
    http://www.arcdesigns.net/carpc/
    My TL CarPC ver2
    FSR Flash Skin w/ moving weather maps
    Mar 2001
    Phoenix
    Post
    I have an Alpine CVA-1005 and it has an illumination input that dimmes the display when I turn on my driving lights. You might want to check the wire diagram and see if you have such an input.
    Steve
    Maximum Bitrate gizmomkr's Avatar
    Dec 2000
    Smyrna, Ga, USA
    Post
    I have a removable lcd, (not head unit mounted) and I would say its pretty bright.
    It does adjust, but at the lowest seting, I would still call it bright.
    I put tint over mine too
    Gizmo-
    Techonlogy on Wheels
    http://www.hjnetworks.com/car
    moahdib's Avatar
    Jul 2000
    Post
    haha glad to know im not the only one that has a piece of glass with tint on both sides just to cover up the screen at night =) you can light up the whole interior of your car otherwise hehe
    My TL CarPC ver2
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    Post
    have you guys thought about hooking up the backlight inverter power supply to the illumination wire on your head unit? that would control the power going to the inverter, and (maybe) give you the ability to dim when you turn on your lights
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    I'M DEBT FREE!!
    I'm now a reasonably successful gunblogger.
    Dec 2000
    Smyrna, Ga, USA
    Post
    I see what your saying.... its no so much the problem of having a switch to adjust it.... I could wire a pot.
    I never looked over the stuff on my inverter board, but I doubt it would work right if I just attached a pot to it.
    That would be like ataching a dimer switch to flourencent lighting. (never tried it, might even run for a little while, but my guess is -eventually you would blow the dimer box first, then if you kept replacing that, or you had a hi-current dimmer, you would blow the transformer / starter for the fixture)
    Gizmo-
    Live and Kickin'
    Arby's Avatar
    Dec 2000
    Houston
    Post
    You can't dim Cold Cathode tubes (backlights)
    They will only work above a certain voltage. If you try to dim it, it will just shut off. (trust me, I've tried )
    Apr 2001
    NJ, USA
    Post
    There are some units that have a dimmer setting. Mine's got that. I also got the screen saver on one minute and then it goes to a black screen with stars, which works well when night driving. The only thing, and I'm still new to this, is that while booting up the screen appears to flip out, moving from bottom to top over and over, and even for the Windows splash screen. Yet, when Windows' desktop appears everything's cool. I guess it's some resolution/LCD thing.
    P4 2.4GHz, Intel mobo w/onboard sound & video, 128MB memory, 100GB Seagate Momentus laptop drive, Xenarc 700TSV 7" touchscreen, IRman using Girder, 150W Opus dc/dc psu, Alpine CDA-9835 h/u, MBQuart speakers, Infinity 15" sub, MTX amps.
    Live and Kickin'
    Arby's Avatar
    Dec 2000
    Houston
    Post
    The windows startup screen is 320x400, a really wierd resolution. Open c:\windows\logow.sys with an art program
    May 2001
    Cincinnati, Ohio
    Post
    On my 15" flatscren LCD display at work the windows startup screen flickers like yours does.
