NoOriginally Posted by viguera
he said he just has the USB type connector plugged in not the power
is this not a blessing if you don't have to run an extra power cable? lol
But he said he had power going to the USB type connector...Originally Posted by antimatter
Just as if using the AC adaptor, 12-v power from the carputer PSU is fed into the "pseudo-usb" connector cable on the side where the RCA connectors are (but not to the RCAs of course!). Then, the "pseudo-usb" end is plugged in to the monitor.
yeah if he has power going to the barrel plug on the cable that has the USB connector then that would be correct that it would power the screen. 1 of those pins in that USB style connector actually just goes into the positive pin of the power connector that is on the mainboard
肚子笑痛了
S60 Install
Okay. The cable looks like this:
On computer end, there are 3 RCA plugs (for Video-1, 2, and audio), plus a connector to plug to the AC adaptor (or PSU).
On the monitor end, there is the USB looking thing (connected) AND the other end of the power cable (not connected).
So I have 12v even if I am not plugging in the power connector on the monitor end. Not only that, but that 12v coming in is somehow getting routed correctly to turn on the monitor!
Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
Oh...okay...so why have the power plug on the monitor end?Originally Posted by jcdillin
If the monitor powers up as you connect the USB like jack then one, two, or even all three provide(s) the power. Have you even metered which one/ones?
EPIA Nehemiah M10k, M1-ATX, 20GB 4200 RPM 2.5", 256MB RAM, Win XP Home, Gyration RF Keyboard & Mouse, Zoltrix Nightingale Optical 4.1 PCI Sound Card, Lilliput 619GL-70NP, XM-PCR w/ optical upgrade, Garmin GPS-25LVS, Microsoft MN-710 USB Wireless NIC
The RCA (Video) thinggy to USB-lookalike does carry 12V power.
On the RCA end, you have V1, V2, Sound, and the Power connector. The other end going to the USB-lookalike. If you connect:
V1 -> Video source for video
Power Connector -> Wallplug 12V output. The screen will be power on.
In another word, there are 2 way to power the Lilliput: The normal way which is the Power connector on the monitor OR thru that USB-lookalike cable.
I found out that when I watching movie on the Lilliput.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
Any guesses as to why they even included the power connector on the monitor end if USB thingy is already providing power?Originally Posted by MatrixPC
I guess not everyone uses that plug, like I dont, so it's just for options or the other thing I was thinking was to power some camerasOriginally Posted by Zebelkhan
肚子笑痛了
S60 Install
