Results 1 to 10 of 14
Thread: Lilliput works on home pc but not car PC!!!!!!!!!!
    Jun 2005
    This is really aggrivating. After trying to figure out what the hell is wrong with this damn thing and why i kept getting an unrecognized usb device on my car pc, i tried on my home pc, HURRAY IT WORKED!!! Okay so i know this thing is not DOA but WTF !!
    Any ideas why this thing is not working on my car pc, but will work on my home pc?? Im running windows xp w/sp2 on both computers.
    Mike
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    going through USB extension? hub? how do you have it powered?
    肚子笑痛了
    S60 Install
    Jun 2005
    its plugged into the usb port on my mobo (biostar mcg400) directly, being powered with the ac adapter that came with it, the car pc is sitting on my desk running of a power supply out of a micro atx case.
    Mike
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    Any other ports on the MB you can try? Did you try manually installing the drivers for it?
    Jun 2005
    yes i tried manually installing the drivers, when i direct windows to the ini file, it says "this file contains no information about your hardware"
    when i try to let it do it automatically with the cd in the drive, it says it cannot find software.
    I tried dlin the egalax drivers and directing the program to those as well, no luck.
    Mike
    Jun 2005
    x
    12345
    Jul 2005
    BC, Canada
    when installing the touchscreen drivers, your touchscreen + vga connection needs to be plugged in... just a tip incase you aren't doing that
    Low Bitrate mike-e-mon's Avatar
    Jun 2005
    Hi lax,
    I checked the closest MB I could find do what you list was the M7NCG 400. But here are few thing you could try. I search some forum and found no one having a USB problem like you described.
    1 Can you install any other usb devices?
    2 Have you tried using any of the other 4 front USB ports?
    3 Did you make sure you have the newest MB drivers install (Biostar list 1.14 as newest and Nvidia has 5.10)?
    4 You could also try updating the the MB bios.
    5 If all else fail RMA the board.
    Good luck,
    Mike
    Jun 2005
    hmm
    could this have anything to do with it? When i direct the windows driver install program to havedisk>touchkit.inf it says " The file contains no information about your hardware" so i was reading the .inf file and it says at the top of the document
    "***** PLEASE READ ***********
    ;; The wizard cannot create exact INF files for all buses and device types.
    ;; You may have to make changes to this file in order to get your device to
    ;; install. In particular, hardware IDs and logical configurations require
    ;; intervention.
    ;; The NT5DDK documentation contains an excellent INF reference."
    what does this mean???
    Mike
    Jun 2005
    x
  1. My Aussie Car PC System
    By vxcarpc in forum Show off your project
    Last Post: 10-17-2007, 07:12 PM
  2. First install of car pc working :)
    By optip in forum General Hardware Discussion
    Last Post: 09-09-2006, 08:13 PM
  3. FS: Complete CAR PC System
    By arise360 in forum Classified Archive
    Last Post: 04-24-2005, 10:17 PM
  4. basic car pc idea
    By Joseph in forum Newbie
    Last Post: 11-08-2004, 03:04 PM
  5. Media Car not responding... Lilliput problem?
    By carpcnoobie in forum MediaCar
    Last Post: 09-01-2004, 02:38 PM
