Results 1 to 3 of 3
Thread: LCD backlight
    Apr 2001
    Schaumburg, IL (NW Chicago Suburbs)
    Post LCD backlight
    Whats the deal with the LCD backlight? Do you control it with a pot? Switch? Both? Does it suck much power? If you have the polarized film on your LCD does the backlight still work good? Thanks.
    -Kev
    May 2000
    Ft Gordon, GA
    Question
    got a similiar question. my pot for my contrast has to be turned all the way p to see the chars on the lcd. is thsi normal or should i replace the pot? if so what should i replace it with. thx,
    etrik
    "if everything is under control, you're not going fast enough!"
    Live and Kickin'
    Arby's Avatar
    Dec 2000
    Houston
    Post
    If you used a 10K ohm pot like on the diagram, It will only work in a very limited range. A 100-500 pot would be much better.
