Results 1 to 10 of 10
Thread: SP-716 Question
    Aug 2005
    SP-716 Question
    Hi Guys/Gals
    I just recently bought a SP-716 indash monitor from Yuki on ebay. But I can't seem to get the screen to open. I pressed the open botton quite a few times. I powered it up inside my home using a spare fully charged car battery. The led turns on, but the screen does not open. Do I need to hook it up to a computer and install the driver? Or did I just received a defected one? Please help.
    Raw Wave kickercivic1's Avatar
    May 2003
    Florida
    You just got a messed up unit.
    Raw Wave BoyNextDoor's Avatar
    Aug 2004
    Walden, NY
    Quote Originally Posted by kickercivic1
    X2 but how did you wire it? Check that... oh, and b/c we have the answer...
    Aug 2005
    Thank you guys,
    I have contacted yuki and customer support should contact me within 24-48 hrs he said. Hopefully it was my wiring but I don't think that was the case.
    Newbie shahin_xp's Avatar
    Jan 2005
    Vancouver
    make sure you have enough current on the power lines. Also does the unit lightup?, if not the wiring was probably wrong. Also check the fuse.
    HTH
    shahin
    Red Prelude.
    MP3 project done
    NOT A NEWBIE.
    May 2003
    Florida
    Quote Originally Posted by shahin_xp
    .. All the front thing that lights up is OSD board which plugs into the controller. SO that mean the fuse is fine
    Maximum Bitrate digitalww's Avatar
    Sep 2002
    ILLINOIS
    Did you ground the green wire (ebrake wire)? what about the red wire (ignition wire)?
    when testing connect black with green and red with yellow.
    Armen
    Quote Originally Posted by tokyo81
    Hi Guys/Gals
    Aug 2005
    Thank you everyone. I was able to fix my problem. I turns out I had a loose connection. So there was not enough power to power up the screen. Only enough to light up the leds. LOL.. Thank you every for being really really really helpful.
    Aug 2004
    Walden, NY
    these are the noobs we need. hey he sad thank you... how often do you get that?
    Nov 2004
    I am having the same problem. I am using a 1.5 amp power supply. It was enough to power a different screen so i figured it would be enough for this one.
  1. Newbie question
    By jaydm in forum General Hardware Discussion
    Last Post: 10-21-2006, 11:07 AM
  2. Paint And Polish Question
    By gboy in forum Fabrication
    Last Post: 08-13-2005, 08:22 PM
  3. M1-ATX /w SP 13000 mobo
    By babazoid in forum Power Supplies
    Last Post: 07-06-2005, 09:57 AM
  4. little question ive pondered..
    By John Crowe in forum Newbie
    Last Post: 04-06-2005, 05:09 AM
  5. DVD drive question
    By Pokey in forum Newbie
    Last Post: 05-11-2004, 05:26 PM
