Results 1 to 9 of 9
Thread: help with install
    Aug 2005
    help with install
    I need to install my 7 inch tview touchscreen to my civic. I do not know where to run the 12v wire to. Does anyone have a diagram or pictures on how to run the wires so that when i turn on my car my monitor turns on. anything will be very helpful thanks.
    Elsewhere
    Quote Originally Posted by BIGMO
    1) Quit reposting the same question over & over again.
    2) The reason you reposted the same question is because you didn't get an answer. Why didn't anyone give you an answer? Because this has been covered in the LCD forum over and over again.
    3) Did you get a manual with your TView? Did you read it?
    4) Did you attempt to contact the manufacturer for assistance?
    5) Did you search these forums for a related keyword (perhaps TVIEW as a keyword would yield some useful results)?
    How about the Wiki?
    Maximum Bitrate MaleBuffy's Avatar
    Aug 2003
    Greece
    LOL, Darquy...why are you posting the same answer over and over again. This has been already covered!
    Elsewhere
    Quote Originally Posted by MaleBuffy
    So that the n00b will at least know what he/she needs to do to locate his answer.
    Call it a shove in the right direction.
    How about the Wiki?
    Jul 2005
    U.K.
    Quote Originally Posted by DarquePervert
    Yep find someone who’s not stuck up his own rear end.
    I will help you out on this on M8, even though you might be in the wrong place.
    After all, if your going to find the time to type it might as well be constructive.
    Get yourself a cheap multi-meter, and set it to DC, expose your ignition switch so you can see the wiring, with your meter turned on put the black to ground (earth) now test the wires with the red end and find a wire that gives you a 12v reading only when the ignition switch is turned on. When you find it, connect your switched live from the screen to it.
    Hope this helps
    Elsewhere
    Quote Originally Posted by regal
    And telling someone to RTFM isn't constructive?
    I think it's far more constructive than giving someone a step-by-step procedure.
    Let people learn for themselves. They become more educated.
    How about the Wiki?
    Aug 2003
    Greece
    I dont think he will find the info Regal mentioned in any monitor Manual, however you are both right, stop this. BIGMO has his info, will probably ask a stupid question again, DarquePV will probably repost himself and someone kind enough will answer the stupid question asked by BIGMO or any other noob. Thats life...live with it!
    P.S. What colour (or color, depends on where you live) is the standart 12v line of a car?
    Newbie shiboilee309's Avatar
    Aug 2005
    CA
    just hook the screen up to your ignition switch. i mean the for the power to the ignition so whenever u urn on the ignition on it will just automatic power up ur screen.
    Aug 2005
    CA
    just hook the power wire to your ignition switch.
  1. 2002 Montero Limited Install...
    By Squid in forum Show off your project
    Last Post: 10-06-2009, 04:41 PM
  2. XC90 Install - am I the first??
    By klokman in forum Worklogs
    Last Post: 02-13-2007, 01:12 AM
  3. 94 Jeep Grand Cherokee Install
    By jamiewhittingha in forum Show off your project
    Last Post: 08-02-2006, 02:02 PM
  4. Phase 2 Peugeot 306 Install
    By 306carputer in forum Worklogs
    Last Post: 02-10-2006, 09:00 AM
  5. How should i install this?
    By jnusaira in forum General MP3Car Discussion
    Last Post: 08-13-2004, 04:03 PM
