Results 1 to 10 of 13
Thread: Messed up VGA/USB cable
    Newbie carfreak01's Avatar
    Aug 2005
    I had my lilliput working fine. The cable did not reach to the passenger seat so I went out and bought a VGA extension cable and a regular 10ft USB cable. I connected the vga and worked fine. Now for the Usb cable, I spliced the original usb/vga cable to connect the extension usb cable. Wired the cables, red,white,black,yellow. Then I connected the usb cable back to the pc and now windows said it did not recognize the device. Sometimes, one in out of 30 tries I got it to recognize. But failed to install. Now I rewired back the original usb plug and it is the same. Have any of you guys spliced the cables to extend them? If so did you have any problems?
    Nov 2004
    NY tri-state
    Quote Originally Posted by carfreak01
    I know it doesn't help now, but you should have bought a bone fide USB extension cable (female to male) and used that instead. It keeps you from hacking the original cable (which obviously didn't work) and makes everything much easier to uninstall if you need to move anything...
    Regardless, you can get a replacement USB/VGA cable from Armen for $15, so I'd say just go that route and get an extension for the USB and avoid the hassle.
    Newbie Craigus's Avatar
    Aug 2005
    Australia Mate
    The max cable length recommended between a USB computer and USB interface is 5 meters. Longer runs can be achieved thru the use of POWERED USB HUBS. not your problem is it?
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    yeah i suspect you have a bad connection that is effectively taking you over the 5m limit. I would get a new USB connector and solder it to where you cut the cable and then connect a USB extension.
    good luck
    Aug 2005
    Thanks guys but I have already wired back the original usb plug and one out of a million tries it works. Ive even tried to twist the wires how they are originally. I know i should of bought a female male extension but i wanted to have my carpc finished.. Anyone of you have hacked (spliced) the wires before?
    Mar 2004
    Bristol
    you could open up your screen and solder a new lead direct to the controller. but be careful. Splicing the wires should not mess it up as one of the xenarc mods is to do that to get it powered off the PC not the screen.
    Aug 2005
    Im gonna keep trying, if anyone has this vga/usb cable let me know I need it to be shipped overnight so I can get it tomorrow. This is my first time building a carpc and im struggling
    Aug 2005
    Ok now I tried connecting directly the usb extension cable directly to the lilli board and still doesnt work
    Mar 2004
    Bristol
    you sure you got the pinout right?
    Aug 2005
    well i didnt completely removed the 4 wires,I just spliced a little of each of the four and connected the usb plug that i had
  1. WTB: Touchscreen VGA/USB cable
    By carfreak01 in forum Classified Archive
    Last Post: 08-22-2005, 04:18 PM
  2. Longer Lilliput VGA/USB cable?
    By NaFooEsi in forum LCD/Display
    Last Post: 04-26-2005, 03:50 PM
  3. Replacement Lilliput VGA/USB cable
    By CCristo in forum LCD/Display
    Last Post: 03-25-2005, 04:46 PM
  4. WTB: Lilliput vga/usb touchscreen cable
    By tczbu in forum Classified Archive
    Last Post: 01-24-2005, 04:07 AM
  5. Replies: 6
    Last Post: 12-21-2004, 03:47 PM
