Results 1 to 9 of 9
Thread: onboard tv out sucks!
    moahdib's Avatar
    Jul 2000
    Post onboard tv out sucks!
    These onboard TV OUT sucks ... mine just died on my MSI-6215...and guess what. It's the SECOND ONE. I'm gonna have to send this one in too and say it's deffective. I wonder how many times they will let me do this lol.
    It works fine from home..just when I put in the car it just "breaks". I have a feeling it's some kind of voltage potential accross the video cable from the LCD to the carputer since I was powering the LCD through the cigarrete lighter adapter( different ground point). Should I run the power for the LCD from the computer power supply instead??? I'm really confused as to what's causing my tv out to mess up.
    I have already grounded the computer case I will add another ground to inverter heatsink as well... i don't wanna mess up another bookPC. THey might not replace it next time around hehe
    I just spent the last 30 min drawing my current system wiring on paintbrush.. Can anyone point out what else I should modify / add??
    [ 07-06-2001: Message edited by: moahdib ]
    04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
    Fast car, fast PC. ;)
    http://www.arcdesigns.net/carpc/
    My TL CarPC ver2
    FSR Flash Skin w/ moving weather maps
    Oct 2000
    Vancouver, Canada
    Post
    All I can say is you did a nice job on the diagram.
    95 Honda Civic DX Coupe - In Progress
    mp3civic site
    Nov 1999
    Ishoej, Denmark
    Post
    I would recommend using the 12 from bookpc, mainly because the power from your battery isnt "clean", it has spikes, going above and below 12 volts.
    Typically when you start your car the voltage goes fairly low, and you may get spikes up to 17-18 volts when running.
    there has been several post earliere that has better and more exact info on this.
    There may be one problem though, can the powersupply make the required amount of amps on the 12 volt line ?
    Mar 2001
    Post
    You're lucky yours still works at home. Try powering the LCD off the 12v from the computer PS and see if that fixes it. If so you can save yourself some trouble.
    The tv-out on my bookpc is completely dead, even at the bench. Waiting for my MSI-6215 to arrive.
    Player: Celeron II 633MHz, 256MB RAM, 20GB IBM 9mm 2.5" Laptop HD (180G/2ms), onboard ethernet/sound/video/tvout, 10"11"x3" case, MPBS1 70W DC-DC PS w/auto-shutdown controller, in-dash lighted switches, 7" NTSC TFT widescreen in-dash LCD, touchscreen, rear-window brake light installed Garmin GPS35 GPS, credit card sized IR remote w/IRMan, mini-wireless keyboard/mouse (sits under seat), PowerMate black knob, MP3s and GPS Navigation (Winamp, CoPilot, SA8.0).
    Car: 1993 Nissan Maxima, Black Emerald
    moahdib's Avatar
    Jul 2000
    Post
    hmm i should have rephrased that... the tv out is completely dead. Doesn't wokr at home anymore. =(
    My TL CarPC ver2
    Mar 2001
    Post
    What's the ohm resistance on your tv-out port?
    In the past when I've seen some tv-cards (not onboard) go bad, their resistance changed.
    Mine is still 75.0 on the dot, though, which is what I believe it's supposed to be.
    moahdib's Avatar
    Jul 2000
    Post
    how would i measure the resistance? just with a multimeter on the rca tv out plus and minus?
    My TL CarPC ver2
    Aug 1999
    Upper Marlboro, MD 20772
    Cool
    always get your power from the PSU, simply because it is clean and regulated.
    abcd-1
    Mar 2001
    Post
    yeah moahdib. multimeter on the tv-out port. the inside and outer edge.
