Results 1 to 5 of 5
Thread: How to get tv out from start?
    Jun 2001
    Post How to get tv out from start?
    i got a ati rage fury with tv out. How do i set it so that when i start my comp.. the video will comp out of tv out.. instead of normal vid card output?
    May 2001
    Post
    well, with my ati xpert all i have to do is plugin the composite-out and leave the monitor unattached and it puts out perfect...hope that helps you. if not, try installing the ati-specific drivers for your card (not the ones that come with windows) and try enabling tv-out from your display properties.
    Athlon 500, 128 MB, ATI Xpert 4MB AGP TV-Out, Sound Blaster Live! Value, 8.4 GB, 2x20 Backlit LCD, Keypower 250 Watt ATX DC-DC, DSchmitd Startup/Shutdown Controller, IRMan + Backlit IR Remote, Custom Keypad, 5.6" NTSC LCD, In-Dash Slot Loading DVD, all installed in an '87 Honda Accord LX-i
    Dec 1999
    Austin, TX
    Post
    I'm using an older ati card, and had to make up a dummy 75ohm load so that the card would think there was a tv hooked up.
    The way my card works is that it goes into TV-out mode on bootup if it detects a tv attached, but the card wouldn't detect my screen if it was powered off at bootup. So I took an S-video jack, soldered a 75ohm resistor to the correct pins, and plugged that in. Now the card always thinks there's a tv attached.
    Radio Shack is good for something.
    This only works if you have both S-video and RCA outs.
    Aug 2000
    Abbotsford, BC, Canada
    Post
    Originally posted by LoreleiGuy:
    <STRONG>I'm using an older ati card, and had to make up a dummy 75ohm load so that the card would think there was a tv hooked up.
    This only works if you have both S-video and RCA outs.</STRONG>
    Cool - Can you please post a simple, idiot(me)-proof diagram?
    TIA!
    ~m
    PII 266, 512 MB RAM, 10 Gig, 36x CD-ROM, 16x DVD, DeLorme GPS, 5.6" LCD Screen, Dschmidt power controller, Keypower ATX DC-DC Supply, PowerAmp Macro controller, Dauphin mini-Kbd.
    Sony Head Unit, Sony Unilink input selector, rear deck Kenwood 6x9's, stock door spkrs... All in my '96 Civic, of course :}
    BC ROCKS!!!
    Dec 1999
    Austin, TX
    Post
    I'll give it a shot. The S-video pinout is rather simple, given that there are only 4 pins.
    The pinout:
    Code:
         4.  3.
        2.    1.
    Pins 1 and 2 are ground, pins 3 and 4 are Luminance and Chrominance respectively. That's not important, what is important is that you want a 75ohm resistor between them and the grounds.
    Code:
       75ohm--4.  3.--75ohm
           --2.    1.--
    It was a while back that I did this, so I'm not sure if that's exactly the way I did it, but it's certainly the same principle and should work.
