Results 1 to 8 of 8
Thread: PSone LCD up in smoke
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Ok, here's the deal. Somebody else on this board had the same idea as me, and I hope you read this before you f something up.
    I had this great idea about hooking up my PSone LCD to the PSU of my carPC. PSone takes 7.5v. So, I hooked the ground to the PSU 5v and the positive to the psu 12v. This creates a 7v circuit. But here's the bad part. It worked all fine and dandy when I was checking it inside with a PSU that I had lyin' around just to see if it would power.
    When I hooked it up in my car, I didn't realize that the screen grounded itself thru the VGA cable until it smoked. Then it dawned on me. I just hooked up 5v to ground and 12v to my screen. So I had all kinds of ****e smokin'. But, live and learn I guess.
    I'm basically posting this so anybody with this bright idea will realize, it's not all that great, unless you're tryin' to let the blue smoke out of your screen. Just remember, once you let it out, you can't get it back in.
    Tidder
    Try RevFE
    Aug 2005
    I was thinking of hooking it up the same way so how would I correctly hook it?
    Sep 2003
    New Mexico, USA
    Get an automotive power adapter for PSone, MAKE SURE IT's SONY BRAND! Then cut it up and hook it to your CarPC's PSU 12v and ground. That's the only way. Or get DC to AC inverter, and just use the power adapter that came with your PSone. It's cheaper to just use the automotive one though. I had mine set up like this for a while, until the adapter stopped working. It was $5 w/shipping from Ebay. Sony branded adapter is about $20. I thought I was saving, but no, it only lasted about 4 months.
    Tidder
    Try RevFE
    Aug 2005
    So if I were to chop off the end of the cig adapter I would wire it to the yellow, +12, and 1st black, Ground for 12 volts, of a molex connector? Perhaps this is a silly question, but how will I know which wire is positive and negative after lopping of the cig adapter?
    Sep 2003
    New Mexico, USA
    On the cigarette adapter, the tip is positive and the barrel is ground. So just go off of that.
    Other than that, yes, you are correct on that wiring.
    Tidder
    Try RevFE
    Sep 2003
    New Mexico, USA
    Quote Originally Posted by ToMMyKiSS
    we dont need no water let the motha burn burn burn motha burn
    Oh my god it's on fire... Then I pulled the plug, and that's the way it was.
    Tidder
    Try RevFE
    Maximum Bitrate pRoFiT's Avatar
    Apr 2005
    Fresno, CA
    You could build a 7 volt power inverter. Or use a lm7808 to get 8 volts. Shouldn't be that bad to run 8 volts to a 7 volt device. Although the LM7808 cant handle more then one amp. Anyone now what the current draw is from the psone screen?
    Um, I guess this is where you put something witty.WITTY
    My Web site, in the design stage. http://home.comcast.net/~cstrachn
    Modified RRSkinEditor http://www.mp3car.com/vbulletin/rr-skins/65723-rrskineditor-bugs-fixes-comments-current-progress-outdated.html
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    I'm pretty sure I got the current draw below 1A by gutting the bits I didn't need : psone LCD > VGA question
    Think it was about 800mA.
  1. Replies: 0
    Last Post: 06-17-2005, 02:51 AM
  2. FS: Sony PSone modded lcd
    By woeful in forum Classified Archive
    Last Post: 04-29-2005, 07:19 PM
  3. graphic LCD or PSOne LCD
    By hannibal in forum LCD/Display
    Last Post: 09-26-2004, 09:40 PM
  4. Anyone know of a controller for a psone lcd?
    By v13 in forum LCD/Display
    Last Post: 08-11-2004, 08:29 PM
  5. Replies: 10
    Last Post: 01-27-2004, 10:53 PM
