Results 1 to 5 of 5
Thread: Help with wires
    May 2005
    Help with wires
    Can someone help with these wires please so I get it correct...
    I bought this unit from Ebay it is the motorised unit which is going around with built in tv tuner.
    In the instructions it says..
    Black line is connect with GND
    Red line is connect with Control switch for lighting
    Green line is connect with control for backing or GND
    Yellow line is connect with + battery.
    Ok obviously black is Ground or -. Yellow is positive or +
    What are the other 2 for ? Which one goes to the ignition ?
    Cheers
    Maximum Bitrate neon_eddy's Avatar
    Nov 2004
    Ham Lake, MN
    red is the switched line .. the green looks like a secondary ground
    Shawn
    Check out my web company Minneapolis Web Designer | MODx Web Design - Himmelberger Design
    May 2005
    Quote Originally Posted by neon_eddy
    thanks for the reply
    switched live is ignition correct ?
    why would it have 2 grounds ?
    Nov 2004
    NY tri-state
    Quote Originally Posted by Froogle
    Switched = ACC. You need to find an "accessory" line in the car, probably so that the thing turns on only when the car is on.
    Green is for reverse... I think the only way to get this is either hooking it up to the reverse lights (assuming that the thing has an auto-switch mode when you get in reverse, for a backup camera). If you can't get to that, then you just ground it.
    At least that's what I've seen from the other similar units discussed here.
    May 2005
    Quote Originally Posted by viguera
    So I can just wire this one to the ignition then ?
    The constant live will be to keep the clock working
  1. correct way to run power & speaker wires?
    By michaelrj9 in forum Car Audio
    Last Post: 07-16-2005, 04:59 AM
  2. how do you hide your wires
    By theheel in forum General MP3Car Discussion
    Last Post: 04-16-2005, 09:16 PM
  3. Power wires inquiry
    By maxxell in forum Power Supplies
    Last Post: 03-27-2005, 03:33 PM
  4. Replies: 16
    Last Post: 07-30-2004, 12:46 PM
  5. Opus Wires Guage Help!
    By mikeyg35 in forum Power Supplies
    Last Post: 04-04-2004, 07:29 PM
