Results 1 to 8 of 8
Thread: Noritake Displays...
    Unregistered User ODYSSEY's Avatar
    Feb 2001
    Raleigh, NC USA CarPC Ver3: [▓▒▒
    Question Noritake Displays...
    Has anybody found a decent plug-in for Noritake VFD (4x20) displays using direct parallel connection? I have yet to find a good one. I have no problems with my 2x20 display, but the 4x20 output is bad. Would a serial piggyback work better?
    ODYSSEY
    ODYSSEY
    Quote Originally Posted by Tidder View Post
    Digital-Car UK|
    (\__/)
    (")_(")
    Jun 2001
    Boise, ID (USA)
    Post
    Good luck, I had the most success with lortys plugin but even then it was tricky. The VFD is so much more sensitive because it is very fast responding and you see stuff you dont see on a lcd. Also, mine had lines 2 & 3 reversed and lines 3 & 4 would only allow text to be displayed to the 10th digit. Later found out you had to add 15 to the location to get past 10th digit.
    I have decided all the extra headache is just not worth it and am going to buy one of arbys reversed units.
    Just this mans opinion - throw that display in the trash before it drives you crazy
    1999 voyager pontoon boat
    (soon to be computerized)
    Registered User
    Apr 2000
    New Concord, OH, USA
    Post
    I got one right after you did and have tried a couple plugins and have been using LCDisplayer(http://www.geocities.com/SiliconValley/Peaks/9546/player/LCDisplayer.html) with out problems. I also have the line 2&3 problem so I can't use a multiline spectrum analyzer but that is OK, the single line one looks great and it gives me more lines for text. I have the spectrum analyzer on line 4, Title center/scrolling on line 1, Artist left on line 2(3), playlist number/total songs, time remaining on line 3(2).
    Mar 2001
    Perth, Australia
    Post
    lorties plugin has an option to reverse lines 2+3 to make the vfd normal
    Jun 2000
    Post
    I have a Noritake 4x20 VFD and I use Lorty's Registered plugin that has lines 2+3 reversed. It works quite nice, once you figure out the VFD.
    My current plans and progress on my install Here
    Variable Bitrate peter3's Avatar
    Feb 2001
    The Netherlands (deventer)
    Post
    Take a look at this page maybe this plugin will do the trick for you
    www.markuszehnder.ch/projects/lcdplugin/index.htmlI love this plugin because you can controlle winamp with 4 buttons.
    Peter3
    P133(yeah got a bit up) 4.3Gb 2x16 ac-dc
    PETER - THE NETHERLANDS - DEVENTER
    sproggy 2.8,epia c3-800,20Gb 2.5", 5.6"lcd,touchscreen.
    Maximum Bitrate Raas's Avatar
    Jan 2001
    The Netherlands
    Post
    Yeah.. true,
    but you may want to use extra buttons for :
    |< << [] || > >> >| , and one for shuffle or something.. (it would be quite a hassle if you want to search in a song, playlist or something...)
    I'm happy this plugin can do this also
    Greetz
    Raas - The Netherlands
    ME: VIA epia m10000, lilliput 7', opus 150w, 80gb<br>
    GF: IBM Thinkpad 380, ext. 3.5 80gb, 40x4, PB-IR
    Here is why.
    Those noritake SCPB lcd emulation displays are NOT HD44780 compatible.
    on the contrary, they are HD66712 compatible.
    A program called LCDhype can drive those very well. no line switching, no nothing.
    it works perfect, AND you can code your own scripts for the display using built in scripting functions.
