Results 1 to 10 of 13
Thread: PSone LCD
    Sep 2000
    LA, CA, USA
    Post PSone LCD
    Hey... thinking about putting a few of these in my headrests....anyone have any experience with them? Know of anything cheaper?
    http://www.buyrite1.com/playsta/psonelcd.html
    Jun 2001
    netherlands
    Post
    just received my ps one screen and everything is clearly readable on the screen for me.
    only downside is that it displays my av in in B/W so i am returning it.
    time for the sig:
    '00 VW golf TDI upped to 130 HP - 18" RS 6 wheels - liliput 7" tft in indash housing - epia 10K - SB audigy - caliber 1 fahrad CAP - RF punch amp - hollywood 1.6K mono amp - boston acoustics pro - RF 10" DVD sub
    Sep 2000
    LA, CA, USA
    Post
    You are getting another unit, correct? Could you tell me the dimensions of the case and if you found a better place to buy from than the link I posted.
    Thanks.
    Jun 2001
    netherlands
    Post
    i havent got exacly the same as youres so i dont know if telling the dimensions is going to help.
    i did "inspect" mine on the inside and the screen module is aprox 12 x 10 cm and with the print behind it it is aprox 3 cm deep.
    better convert these sizes to inches yourself before i screw up
    mine version the screen was easy to take out of the original case to mount in a headrest or something.
    ps i cant beat that price, in europe these ****ers are expensive !
    time for the sig:
    mpt
    mpt is offline
    Jun 2000
    Setubal, Portugal - Europe
    Post
    Originally posted by gerard_NL:
    <STRONG>just received my ps one screen and everything is clearly readable on the screen for me.
    only downside is that it displays my av in in B/W so i am returning it.</STRONG>
    By reading your post it seems that you are inputing a NTSC signal into the LCD and he doesnīt support NTSC, only PAL. Had a similiar problem, not with LCDīs, but with a television.
    mpt
    Sep 2000
    LA, CA, USA
    Post
    Anybody want to buy one of these lcd's and be the guinea pig? I have to wait until i sell my 2 extra 5.6" ones to have the cash to buy these.
    Jun 2001
    netherlands
    Post
    Originally posted by mpt:
    <STRONG>By reading your post it seems that you are inputing a NTSC signal into the LCD and he doesnīt support NTSC, only PAL. Had a similiar problem, not with LCDīs, but with a television.</STRONG>
    allmost right.
    its the other way around.
    a pal signal which i am putting into a ntsc screen.
    the screen is suppost to handle both signals but the switch only stops the screen from "rolling" does not display in colour.
    tried 2 video cards but no luck.
    i can get one of the cards to output in colour ntsc but then i have 0.5" borders around my screen and only 4 " is viewable.
    sucky !
    time for the sig:
    Maximum Bitrate Raas's Avatar
    Jan 2001
    The Netherlands
    Post
    Hi Gerard_NL, Always nice to meet some other people from the netherlands in here.
    I maybe got some information, although it doesn't apply directly to your problem.
    The switch you mentioned is definetly for the PAL/NTSC change. (It has someting to do with the horiz.scan.lines.. I believe PAL has 255, and NTSC Only 200, also with the refresh rate PAL(50Hz) and NTSC(60Hz)).
    (discovered this using a 32-bit amiga and a PAL/NTSC Monitor... screen would role on a normal PAL TV.
    Remember when the First Nintendo 8-bit (Mario) computer where getting really popular. Very soon some companies started to make some 'copy-boxes' for the Nintendo's. This way you could easily copy the game-rom's onto normal floppy disks, load them, and play'em.
    But there was a problem with The French games (and I believe, also the Japanese)
    Because they where designed for the 'SECAM' system (almost similar to the PAL-system). And when you wanted to play these French games, you could only play it BW.
    There was something like:
    When you put SECAM-system into PAL display, the screen only is Black & White, Then,
    When you put PAL-system on SECAM display,
    the screen only is Black & White.
    Again, this maybe lost track from your problem, but 'maybe' this is an explanation for your problem..
    Good Luck !
    Greetz
    Raas - The Netherlands
    ME: VIA epia m10000, lilliput 7', opus 150w, 80gb<br>
    GF: IBM Thinkpad 380, ext. 3.5 80gb, 40x4, PB-IR
    Jun 2001
    netherlands
    Talking
    Hi marc, indeed nice to meet a fellow "lotgenoot" !
    i think you might be right about this secam story, the image stops roling over the screen but isnt colour.
    anyway i found a solution to the black borders thing.
    its a program called tvtool, it can stretch your image beyond screen properties if you want.
    i use it in ntsc output and now it finally works on my ntsc sreen
    WHOOO WHOOO. now onto the next stage, the in-car implimentation.
    time for the sig:
    Jan 2001
    The Netherlands
    Post
    Good to hear that all is working great now.
    Greetz
