Results 1 to 10 of 17
Thread: Powerstrip and Lilliput @ 800x480
    May 2005
    Toronto, ON
    I know this topic has probably been beaten to death, but can some of you share your powerstrip timing settings? My text @ 800x480 seems a bit fuzzy. Other than that, it looks pretty good. Thanks.
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    What video card are you using??
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    May 2005
    Toronto, ON
    Ati Radeon 7000
    Nov 2004
    post 7 and 8 (and I know that there are more in that thread but I let you do the search yourself if the ones in those post don't work )
    Quest for 800x480
    Thanatos.
    Nissan Aux-in MOD
    May 2005
    Toronto, ON
    There are no timings on posts 7 and 8.
    So I've been fiddling around with the timings, and no matter what I do, I can't get the screen to recognize it as 800x480. Not only that, the text seems a bit blurred. I'm pretty sure the image can be much clearer.
    Constant Bitrate AWDNUT's Avatar
    Aug 2005
    Canada
    This should be a sticky:
    That's from Xenarc, and apparently all the clones use the same thing??
    Nov 2004
    This is no a timing??:
    Quote Originally Posted by redmage
    My advanced timings and photos:
    -- HORIZONTAL --
    Front Porch: 32
    Back Porch: 112
    Sync Polarity: -
    Sync Width: 80
    Scan Rate: 37.65 kHz ( Can't be changed )
    -- VERTICAL --
    Front Porch: 61
    Back Porch: 78
    Sync Polarity: +
    Sunc Width: 3
    Refresh Rate: 60.524 HZ
    Pixel Clock: 38.55
    And this one is no a timing either right??:
    Quote Originally Posted by PatO
    Wholy *****! It WORKED! 800x480! I'm using an ATI Radeon X800 (Powercolor) with the display hooked up as secondary. Using PowerStrip.
    -- HORIZONTAL --
    Front Porch: 32
    Back Porch: 112
    Sync Polarity: -
    Sync Width: 80
    Scan Rate: 37.646 kHz ( Can't be changed )
    -- VERTICAL --
    Front Porch: 61
    Back Porch: 78
    Sync Polarity: -
    Sunc Width: 3
    Pixel Clock: 38.550.
    All this for "quest for 800x480 thread".... so next time read better
    Thanatos.
    Nissan Aux-in MOD
    May 2005
    Toronto, ON
    Yeah, I saw those. I tried them too. I got "over range"
    They're for the xenarc screens
    Nov 2004
    Ohh that is a whole diferent story!!.
    And if you read the whole thread like I did you will find out that because you moding the timings with powerstrip those that work with xenarc will work with the lilli.(that is why I say keep looking in that thread).
    Thanatos.
    Nissan Aux-in MOD
    Aug 2005
    Canada
    I just tried this on my laptop (Intel GME) and all the little spinners would adjust *except* the active vertical lines (the most important one), it is stuck at 600 (as in 800x600).. That's just a limit of the driver?
  1. xenarc first impressions, tried lilliput before
    By emdzey01 in forum LCD/Display
    Last Post: 06-09-2005, 07:26 PM
  2. Replies: 3
    Last Post: 03-11-2005, 11:46 AM
  3. lilliput native resolution?
    Last Post: 02-15-2005, 06:29 PM
  4. Replies: 4
    Last Post: 02-08-2005, 06:36 PM
  5. Lilliput 7" @ 800x480
    By ryguy in forum LCD/Display
    Last Post: 12-19-2004, 08:11 PM
