Results 1 to 4 of 4
Thread: Stretching on-screen image using an LCD, possible?
    Newbie evil eye's Avatar
    Sep 2005
    Long Island, NY
    Hey guys,
    I ran a search and couldn't find anything that helped me out. Maybe I'm using the wrong terminology. I am slowly getting the pieces together needed to build my carputer. I am looking to get the Xenarc 7" TSV. For those of you who own one, I would like to know if there is a display option to stretch/skew the screen to a smaller size, much like a standard tube VGA monitor. And if there's an option to position the on screen image around the screen as well. The reason why I ask is that I have an OEM center console for my Celica that has a screen cutout for navigation. USDM Celica's do not have an option for navigation, this part was purchased from Japan. My friend has this same console with a 6.5" widescreen TFT display hooked up to his carputer. 6.5" looks to be the max size for this cutout, but I can't find a VGA touchscreen in 6.5". I plan to remove the 7" Xenarc from its case and attach it to the console, but I need to know if I can skew the image down so that I can center it perfectly as if it were a 6.5" LCD. Here's a pic of my friend's setup using a 6.5 display with the same console I have.
    Thanks guys!
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    So if I understand you right, not all of the 7"er's screen is going to be visible, so you want to scale it down to fit in the visible area?
    I don't know if it can be easily done, but scaling is a bad idea. Unlike a CRT, LCDs have discreet pixels, and scaling invariably makes it look like crap. I think some software that makes windows think it has a smaller display while still outputing VGA would be ideal, but I'm not sure anything like that exists. Your best bet may be to make a frontend skin that works to your space limitations.
    Or, get a 6.5" screen. You say you can't find one with a touchscreen, but touchscreens can be added to any screen. It can be done (though it might get pricey).
    Elsewhere
    I'd suggest getting a spare dash panel and a 7" VGA screen and modifying the opening to accomodate the larger screen. Fromt eh pics, it doesn't appear that you'd need to do a lot of modifications. You'd also end up with a recessed screen, which will help with glare during bright sunlight.
    How about the Wiki?
    May 2005
    Maringá - Parana - Brasil
    if u use nvidia card, u can use nvkeystone to shape the image the way u want, but performance will be affected...
    almost done
    only need display and a car
    already fried 2 PSU, 1 Video Card.
    Broke 3 fans. but i still want a carputer....
  1. Protective case for 20x4 LCD screen
    By ning in forum Fabrication
    Last Post: 01-05-2005, 02:13 PM
  2. Replies: 10
    Last Post: 12-18-2004, 12:12 AM
  3. LCD screen powered by MOSFET inverter
    By warnockm in forum LCD/Display
    Last Post: 11-13-2004, 09:30 AM
  4. FS: 10.5inch touch screen lcd
    By V_C_F_666 in forum Classified Archive
    Last Post: 05-26-2003, 11:44 AM
  5. Replies: 0
    Last Post: 09-29-2002, 11:03 PM
