Results 1 to 4 of 4
Thread: LCD hook up question
    LimpBagel
    Guest
    Post LCD hook up question
    Is it possible to hook a lcd with parallel connector up to a parallel > serial adapter? Or do you actually have to use the parallel port?
    Aug 1999
    Upper Marlboro, MD 20772
    Angry
    Yes, but u will need source code. I recall 2yrs or 1yr ago some site had that info. I wont recommend it at all.
    abcd-1
    Apr 2001
    Here, There, Everywhere
    Post
    just use the parallel port..... you can by LCD displays with a serial interface, they are more expensive though and the software needs to support them.... if your cutting your own software that may not be a problem.
    Scott Edwards Electronics sells them? from memory? (which is poor!)
    Project - GAME OVER :(
    LimpBagel
    Guest
    Post
    I was asking because I cant find the parallel connector for my comp. If its not easy then I won't worry about it though.
