Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Not your typical flicker problem
  1. #11
    phc
    phc is offline
    Variable Bitrate phc's Avatar
    Aug 2003
    SoCal
    Quote Originally Posted by JPuma
    Thanks, I think I cam accross these in the past. So how are you going to solve your problem. Have you done anything yet?
    Yes, on Sunday afternoon I ran pwr+gnd from the Opus up to the dash. No more horizontal interference.
    I wired in a relay from the IGN wire, so the LCD is only on when the key is in the ignition AND the opus is on. The opus is setup to turn off after 20 min.
    www.mechatroniks.com/wrx - Car PC Project/Dash Kits
  2. #12
    Constant Bitrate JPuma's Avatar
    Jul 2005
    NY
    Quote Originally Posted by phc
    Thats exactly what I did. Glad to hear your problem is sloved too, now we can play. I am installing XM radio today when I get home.
  3. #13
    Aug 2005
    what is a POL? power on lead?
  4. #14
    Jul 2005
    NY
  5. #15
    Constant Bitrate AWDNUT's Avatar
    Aug 2005
    Canada
    Yeah I have the same problem but it's more obvious for me..
    I have a JVC GigaMP3 DVD Player and a single DIN 7" panel wired together on the same power and ground. The two are flawless, music and movies are perfect!
    When I turn the CarPC on no extra noise comes into the audio or video, but when I switch the DVD player to line in (for the CarPC) I can hear the noise (the difference in power source) and then when I display to the 7" LCD from the CarPC I can see the noise..
    So now I need a PS that can handle the JVC, the LCD, and my CarPC!? Plus a ground loop isolation circuit for the amps that are powered from a direct power connection?! Ack! Almost tempted to live with the noise when using the CarPC for nav/email/games.. Almost.
  6. #16
    Constant Bitrate Heckle0's Avatar
    Sep 2003
    Colorado Springs
    I've been wasting my time with this issue. Should have done this search here long ago. Thanks for the info. I'm nervous about wiring from my pc psu to the xenarc. Is there anything i should be careful of?
    Another Novice?
    Progress so far <-------*-> 88%
    Kenwood MPV5025 with Aux
    Via MII10000
    512MB Ram
    LG Slim DVD\CDRW
    Xenarc 700TS
    M1ATX
    Pharos GPS
    SYBA USB2.0 4-port Hub
    Bufalo 54Mbs Wirelessb/g PCMCIA card
  7. #17
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    Same Noise Problem
    Sorry to resurrect this Guy's but I'm having the strobing horizontal lines problem too, despite trying all the fixes in this thread. These lines do disappear at times but return randomly for no reason I can figure out.
    I have a LinITX Plus touchscreen and a MiniItx carpc with P4 mobo and M2-ATX PSU. I use a ground loop isolator so no sound interference problems, just video.
    I have tried the following:-
    8 gauge grounding all round (solved a grounding interference issue, but not the horizontal lines)
    Made a common ground for PC & screen ( still lines )
    Powered the screen via the M2 ATX ( still lines )
    Powered the screen via supplied mains adapter ( still lines )
    Set the screen to 75 hertz ( thinner lines !!! )
    Re-routed cables ( still lines )
    I can't replace the VGA cable because on this screen it's an "all in one" solution, where it joins other cables (T/S, power, RCA inputs etc) in a moulding and bespoke connector. ( ie. one composite cable comes out of the screen)
    I guess this is some sort of frequency interference coming down the VGA cable. Can Anyone help me solve this problem
    Car : Ford Focus Zetec 1.6
    Carpc :Lin-ITX Plus 7" touchscreen/Toad 8" roof screen
    Morex 3688 case/M2-ATX PSU/Commell V-672 P4 3.2Ghz/1024DDR2/40GB 2.5" SATA HDD/Sony DVD/CDRW
    BU303 GPS/Mercury 11b WiFi/Parking Sensors
    Colour I/R Reversing Camera
  8. #18
    Jul 2005
    NY
    try powering the pc from another power source other then the battery. I dont know what it will prove as a solution but see if it goes away. I still get video noise on the board monitor when I use it instead of the touchscreen. I solved my problem by powering the touchscreen with the PSU powering the computer.
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 09:29 AM
  2. A little problem with my car... Maybe...
    By BoyNextDoor in forum Power Supplies
    Last Post: 11-13-2004, 09:58 PM
  3. Media Car not responding... Lilliput problem?
    By carpcnoobie in forum MediaCar
    Last Post: 09-01-2004, 02:38 PM
  4. Replies: 8
    Last Post: 12-31-2002, 12:37 PM
  5. ugh.. .screen flicker driving me bonkers! help!
    By 00CericaRuss in forum LCD/Display
    Last Post: 12-11-2002, 05:46 PM
