Results 1 to 4 of 4
Thread: Hard wire power to the Xenarc board?
    Falls Church, VA
    As others may be aware, it looks like i have a modified Xenarc/Gain controller board modded by digitalww. Armen removed the tactile switches and power connector. The power connector section of the main board appears to have 4 holes in the board, and whoever modded it did a relatively sloppy job of solder so im redoing it. Basically, which of the 4 are ground and which are 12v? Im guessing the 2 on the bottom are ground and the 2 on the top are 12v and i should just jump the traces. Can anyone give me a hand with this? what goes where?
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    It will be good if you post a pic.
    I'm old school so what I do in this cases is connect to power source and track it with a multimiter/voltimeter/tester or whatever you ganna call it.
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    Falls Church, VA
    I'll see what i can do when i get back
    Maximum Bitrate digitalww's Avatar
    Sep 2002
    ILLINOIS
    Top 2 are ground on all buttons.
    Armen
    Quote Originally Posted by Will Albers
  1. FAQ: How to Wire an OPUS PSU
    By Quattro in forum The FAQ Emporium
    Last Post: 08-26-2006, 01:38 PM
  2. WTS: Broken 7" Xenarc TSV - VGA Connector Broke Off The Board
    By jeeplaw in forum Classified Archive
    Last Post: 07-16-2005, 11:57 PM
  3. Replies: 4
    Last Post: 05-04-2005, 12:24 PM
  4. Xenarc 700TS / hardwire power
    By dnorrell in forum LCD/Display
    Last Post: 11-29-2004, 11:04 AM
  5. Replies: 4
    Last Post: 10-29-2004, 09:10 AM
