Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 55
Thread: Intel 865 custom drivers
  1. #31
    Apr 2006
    Chicago, IL
    Post
    Great post! I just got my aOpen MiniPC to finally display 800x480 on my Xenarc.
    However, when I began playing DVD's or any other MPEG2 files I noticed that DirectX Video Acceleration doesn't seem to be available. Has anyone else noticed this or found a way to enable it? So far I've only tried the PureVideo decoder - I'm going to try DScalar and others after work (though maybe I'll put them on my USB drive and spend lunch in my car .
    Thankfully MPEG4 and WM9HD seem to run quite well full screen with smooting and scaling applied correctly so I'm converting any music videos I have to Divx.
    I had to install another copy of windows so at boot-up I can choose between the Embedded 800x480 or regular drivers and higher resolutions/DVD. Perhaps I can figure out how to get the driver INF configured so that it's possible to actually change resolutions without modifying the registry/rebooting.
    Since I mostly use the PC for music, gps, and sometimes to play music videos I prefer to run at the native 800x480.
  2. #32
    Jan 2006
    Angry
    please help
    at the moment:
    Intel(R) 82852/82855 GM/GME Graphics Controller
    6.14.10.3943
    LCD K301
    800x600
    where can I find the driver 01/15/2006,5.0.0.756, using 800x480 w 16bit
    what I have to do to get 800x480 ?
    I tried everything without results.
  3. #33
    Jan 2006
    now I found and installed this driver
    then I wrote the values from backspace and my GUID into the reg-File and executed it
    after reboot no effect
    I cannot choose 800x480
    please help
  4. #34
    Jan 2006
    ok, after a new installation I repeat all the things and now I can choose 800x480,
    but the letters not clear
    something is wrong, I have to try other values
  5. #35
    Apr 2006
    Chicago, IL
    I was finally able to get DVD's/MPEG2 looking great but for that I have to use Zoom Player. These drivers seem to be really finicky about when they accelerate video.
    Also, I figured out how to change resolutions - I now can change from 800x480 to 800x600 or 1024x768. Suffice it to say, I deleted the other windows installation and now am quite happy with this setup.
    Basically I just made 2 more entries under the DTD\ registry key (see bold below) and now windows lets me select any of the three at any time. Great for when some pesky dialog window is unusable in native 800x480. You can of course add as many different resolutions as you like - I'm fine with these for now.
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Video\{*****}\0000\Config\1\Port\5\Dtd\1]
    "PixelClock"=dword:00009696
    "HorzActive"=dword:00000320
    "HorzSync"=dword:00000028
    "HorzSyncPulse"=dword:00000050
    "HorzBorder"=dword:00000000
    "HorzBlank"=dword:000000e8
    "VertActive"=dword:000001e0
    "VertSync"=dword:0000003d
    "VertSyncPulse"=dword:00000003
    "VertBorder"=dword:00000000
    "VertBlank"=dword:0000008e
    "HorzSize"=dword:00000019
    "VertSize"=dword:00000010
    "Flags"=dword:00000000
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Video\{*****}\0000\Config\1\Port\5\Dtd\2]
    "PixelClock"=dword:00007530
    "HorzSync"=dword:00000020
    "HorzSyncPulse"=dword:00000078
    "HorzBlank"=dword:000000e0
    "VertActive"=dword:00000258
    "VertSync"=dword:00000003
    "VertSyncPulse"=dword:00000002
    "VertBlank"=dword:00000018
    "VertSize"=dword:00000013
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Video\{*****}\0000\Config\1\Port\5\Dtd\3]
    "PixelClock"=dword:0000fe2a
    "HorzActive"=dword:00000400
    "HorzSync"=dword:00000088
    "VertActive"=dword:00000300
    "VertSync"=dword:00000006
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Video\{*****}\0000\Config\1\Port\5\General]
    "Rotation"=dword:00000000
    "Flip"=dword:00000000
    "Edid"=dword:00000000
    "EdidNotAvail"=dword:00000004
    "PortEnable"=dword:00000001
  6. #36
    May 2006
    Hello
    i tried this tweak on intel i915GM, and seems not to work
    I can't get the 800x480 resolution , i get 720x480 .
    My computer doesn't want to reboot , it freezes on parameters saving ( at the end )
    Does someone have any idea to fix this ?
    Apr 2006
    You Are The Man
    Quote Originally Posted by Merzbow
    Not sure, I'd suggest playing around with the horizontal settings in PowerStrip to find out. I've discovered that these Intel drivers aren't compatible with hibernate on my machine (blue-screens every time), so I'm back to 800x600.
    I just went through your process and it hibernates without any problems.
    thanks a lot man, great work!
    t.
  8. #38
    Variable Bitrate vladcarpc's Avatar
    Nov 2006
    Sao Paulo, Brazil
    Hello,
    I need to translate this powerstrip settings into the driver registry values.
    Can you help me identify what powestrip value goes where in these registry values?
    PixelClock = Horizontal geometry Pixel clock
    HorzActive = Horizontal geometry Active
    HorzSync = Horizontal geometry Front porch
    HorzSyncPulse = Horizontal geometry Sync width
    HorzBorder = ?
    HorzBlank = ?
    VertActive = Vertical geometry Active
    VertSync = Vertical geometry Front porch
    VertSyncPulse = Vertical geometry Sync width
    VertBorder = ?
    VertBlank = ?
    HorzSize = ?
    VertSize = ?
    Flags = ?
    Thank you
    \/ |_ /\ [)
    1995 Civic Sedan EX
    CarPC status: [||||||||||||] 100% - Phase 1 Complete!
    YouTube video - WorkLog
  9. #39
    Sep 2006
    Holy thread revival Batman!
    Comparing the .reg file and Merzbow's screen shot, this is the correlation I see:
    HorzBorder = stays zero
    VertBorder = stays zero
    Flags = stays zero
    HorzBlank = (Horizontal Total) minus (Horizontal Active)
    VertBlank = (Vertical Total) minus (Vertical Active)
    I'm not sure if the Total is calculated automatically by the PowerStrip utility or not - if it's not, I'm not exactly sure how to determine the HorzBlank/VertBlank values.
    HorzSize/VertSize: He was able to determine these numbers from the Intel documentation. But if you correlate your desired resolution with the numbers from Intel, you get:
    HorzSize
    Desired resolution: 800
    Intel's matching HorzSize value = 25
    800/25 = 32
    VertSize
    Desired resolution: 480
    Intel's matching VertSize value = 16
    480/16 = 30
    So divide your desired horizontal resolution by 32 to get HorzSize, and divide desired vertical resolution by 30 to get VertSize.
    Note: I am not responsible if you damage anything by using the above assumptions to modify advanced timings.
  10. #40
    Maximum Bitrate americasfuture2's Avatar
    Apr 2007
    edmond, oklahoma
    bumping for my archive and any future pandora owners out there.
    i have just now read more thoroughly through this, and it is definatlytly over my head. i am going to need a walk through basically. im running the mp915-b.
    Gathering parts----99% (I'll always want something else, its never 100%)
    Learning Centrafuse
    First Actual 98 Blazer LT Install
    First 08 Aveo5 SV Install
    87 Fiero GT waiting
  1. Drivers for a NON touchscreen Lilliput?
    By romeov in forum LCD/Display
    Last Post: 07-20-2005, 05:19 AM
  2. Article: Satellite toll plan to make drivers pay by the mile
    By VanMan69 in forum General MP3Car Discussion
    Last Post: 06-12-2005, 03:05 AM
  3. TouchScreen Drivers & Installation
    By [iG] in forum Input Devices
    Last Post: 02-17-2005, 11:40 PM
  4. How is this motherboard? Intel board inside..
    By sspiro in forum General Hardware Discussion
    Last Post: 01-16-2005, 02:16 PM
  5. Via Epia M-900 Video Drivers Not working
    By mattdisaster in forum General Hardware Discussion
    Last Post: 01-06-2005, 11:33 AM
