Results 1 to 3 of 3
Thread: K301 - Problem with Remote output
    Newbie Nils Schneider's Avatar
    Sep 2005
    Germany
    Question K301 - Problem with Remote output
    Hi there,
    totally new here and already my first question
    I had no problems when installing my K301 InDash TFT, but there's one problem: I'm not able to get any signal from the remote output, I'm always measuring +1,45V no matter if the display is switched on or off. Anyone else with the same problem?
    I wanted to turn on/off my CarpPC (which sits in the back) through the K301, now I had to connect it to my ignition switch instead.
    This is a problem if the PC is crashing while I'm driving, I have no option to reboot it.
    Regards,
    Nils
    Constant Bitrate 00christian00's Avatar
    Apr 2005
    Italy,Ancona
    I wanted to do the same,but my installer told me it wasn't working.
    If someone has some idea.
    Variable Bitrate therussman2002's Avatar
    Mar 2004
    Milwaukee, WI
    anyone think its a remote IN wire? like send 12v into that blue wire to tell the screen to turn on...
    edit: nevermind, i'm an idiot.. the accon wire would tell the screen to turn on, having the remote wire do that sounds redundant
    after reading the manual, my guess is you can solder that wire to somewhere behind another device's IR port, to use the IR receiver on the K301 as the "ir receiver" for an external device, which sounds like a pretty good idea
  1. Not your typical flicker problem
    By JPuma in forum LCD/Display
    Last Post: 05-30-2007, 10:28 AM
  2. Xenarc Problem or Polarity Problem?
    By mbkowns in forum LCD/Display
    Last Post: 01-06-2007, 09:57 PM
  3. PC Remote Control 4
    By Gene in forum Software & Software Development
    Last Post: 07-03-2005, 10:35 PM
  4. ATI Remote Wonder Problem
    By cavramair in forum Input Devices
    Last Post: 03-04-2005, 01:09 AM
  5. ps2 pelican remote w/ creative reciever & girder
    By ShinkunoNamida in forum Input Devices
    Last Post: 04-26-2003, 03:00 PM
