Display icon in the Control Panel (assuming you can get to the control panel).Originally Posted by rustyboxx
Right-click on the desktop and choose Properties.
Launch C:\Windows\System32\Desk.cpl
Does anyone here know how I can configure my vga properties other than through Windows XP. Let me explain further. I inadvertently enabled the extended desktop option on my usb vga card so now both screens show the desktop wallpaper but no icons. I can't get to the taskbar and can't get to the safe mode option when hitting f8 at start up. I'm all out of ideas and its starting to bug the **** out of me. If anyone has a workaround I'd be eternally grateful.
Only true postwhores remember everything they post
REP CLUB IS DEAD
LONG LIVE REP CLUB
Can't you do a system restore? This did the trick for me, as I too fell in that trap.![]()
I wish I could but with no access to any meaningful windows functions I'm stuck. Can a restore be done from the xp disk?
REP CLUB IS DEAD
LONG LIVE REP CLUB
Nobrainer Q first, can't you right click the desktop and get the display properties box up?
If not, perhaps try to reinstall the drivers, that usually knocks things back to default, do you see the program manager when you CTL-ALT-DEL? If yes, go to File, New Task and navigate to your driver package startup.
You didnt post your mobo, if its got onboard gfx why not just unplug the usb vga and connect using the mobo vga, you can always replace it if it goes tits up?
Ive put his script together that will set your display back to 640x480 while the explorer window is open but unless you can run it on boot its not going to be much use. make a txt file, call it test.bat and put
set __COMPAT_LAYER=640x480
start /w iexplore.exe
in it and save, if you can double click or otherwise run it on boot or from the command line, it might work- it does change the res but I can't test it on a dual atm as ive wired my monitors arse about face since i got the L2335 and have disconnected my 2nd screen for now.
Nope, no luck there.Originally Posted by Mad Ad
Nope, just wallpaper. CTL-ALT-DEL works in background but wont show on screenIf not, perhaps try to reinstall the drivers, that usually knocks things back to default, do you see the program manager when you CTL-ALT-DEL? If yes, go to File, New Task and navigate to your driver package startup.
Epia M10K + USB VGA adapterYou didnt post your mobo, if its got onboard gfx why not just unplug the usb vga and connect using the mobo vga, you can always replace it if it goes tits up?
Thanks for that, i've tried f5 and f8 but not getting any screens up. I see the XP startup screen then it goes straight to desktop minus everything except the wallpaper. Right clicking just brings up new folder/shortcut/arrange icons etc. I even tried making a shortcut to the usb/vga folder but no luck. It found it but would not display it.Ive put his script together that will set your display back to 640x480 but unless you can run it on boot its not going to be much use. make a txt file, call it test.bat and put
I'll try again tomorrow night and if i can get to the command line I might have some luck.
Thanks again
REP CLUB IS DEAD
LONG LIVE REP CLUB
ok good, right click, choose new text file, that should make one right there on your desktop you can see, name that test.bat, open it, type in
save it, double click the icon and hope
EDIT: that __ is a double underscore btw
that sounds odd unless it thinks you have 3 monitors
Very strange. You should be able to access the properties with the F8. Try hitting it from the time the pc starts all the way...
What if you unplug the USB video card, and let the onboard card take it's place. Once you entered Windows, uninstall the drivers for the USB card, restart, and plug it back in.
