Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 33
Thread: Xenarc 700IDT is AMAZING!
  1. #11
    Dec 2004
    Sweden
    I know you can get them for under $500 here too http://www.carputersfordummies.com/Xenarc%20700IDT.htm
    Just talked to them about one of these nice screens! Will probably get one myself.
  2. #12
    Quote Originally Posted by markbuts3
    I like mine too, It still gets washed out a little in bright sunlight though.
    Didn't stop you wanting one a while ago
    Well thank you for your valuable contribution to this thread
    http://www.primera-egt.com/mov/Xenarc.wmv
    A bit off topic here, but which navigation software is in used in the video? just curious.
    Thx in advance. (I use Routis (discontinued))
  3. #13
    May 2005
    Rochester, NH
    so this one is not so reflective? Would you still need an upgrade to have good daytime visibility? I have a convertible, so sun is a much bigger deal for me.
  4. #14
    Maximum Bitrate Don 944 LA's Avatar
    May 2004
    San Diego / Los Angeles
    Quote Originally Posted by Gredd
    someone actually registered the domain " carputersfordummies.com "
    seems like a sale site, no info ...
    I thought it might be a good sticky for the noobs
    It seems like the same housing that I got to put one of my lilli in, however it's FUBAR now..... damn, trying to save a penny
    Don
  5. #15
    May 2005
    Derbyshire, UK
    Quote Originally Posted by TheBigDog
    That is ViaMichelin Mapsonic....
    Old setup
    Epia M10k, Cubid 2699R case, 512MB, 40GB 3.5" drive
    New setup
    Optiplex 260SX (2.8GHz P4, 512MB, 30GB, DVD)
    Xenarc 700IDT, USB hub, 802.11g, bluetooth, P2140, P5V
  6. #16
    May 2005
    Rochester, NH
    doesn't that display have the same rated brightness as the lilli? Just the anti glare coating thats making a difference?
  7. #17
    Sep 2005
    hello, I am new to this
    and
    I am wondering if this mechanism is good enough for off-road environments.
    any suggestions for off-road use?
  8. #18
    Maximum Bitrate hd54321's Avatar
    Jun 2004
    Los Angeles
    I had this screen and it's going to the Russman tomorrow. Yeah, I think Xenarc had issues with this unit early on. QA sucked and my first unit wasn't even a true DIN size (about a mm or two too wide). My latest unit, fresh from overseas is rock solid. I haven't fired it up, but the mechanism is great. It feels rock solid.
    Another great thing is that this is an in-dash Xenarc that's fully warrantied. Once you take apart your Xenarc for the in-dash conversion on some other units, your warranty goes bye-bye. You get Xenarc quality in a sleek solid unit which has the possibility of adding a slim-drive to it. Also, let me mention that the unit has internal power regulation. There is a circuit board inside this unit (aside from the Xenarc controller board) that has a relay for power switching and regulation. Also, the unit is relatively low-key. The bluish oval button-looking device is nearly black in the dark. To me, this is important since it lowers the risk of idiot robbers searching for something flashy in a car.
    shameless plug in my sig for my unit...it's pending sale to therussman2002 tomorrow
    -HD
  9. #19
    Jun 2005
    Phoenix, AZ
    Sorry for the late reply, I didn't subscribe to the thread...
    Yes, I believe this unit is rated at the same brightness, but I think that ratings is measured before the TS and glass and stuff. This one seems to be brighter to me. Also, I have discovered that when my windows are down you can not see the picture in direct sunlight. I have 20% tint, and that gives enough coverage for full visibility. I would not recommend this screen in a convertible. I don't think any Xenarc/Lilliput would do.
    If you have a coupe/sedan, get a nice 20% or so tint job and you will be very happy with the results.
    Scott
  10. #20
    Variable Bitrate Viscouse's Avatar
    Jul 2005
    Motor City
    Quote Originally Posted by kickercivic1
    I saw this screen removed from couple of sites and some said because it has issues.
    It was removed from mp3car.com for awhile as well. This was the perfect solution to me. I could leave it out for most of the time, and stow it when needed. I'm glad it's back. I too would like to know what some of the quality issues were. The price seems to have dropped as well. My records show it at $599 before it was taken off. Now it's $440.
    You know you want to...Worklog
    Enjoying v1.0 since it's operational. Aaaawww yeah.
    Specs: Opus120; Epia M10k; 700IDT; GlobalSat BR-355; iGuidance 2.1 & IGMod; XM; Custom case.
    Witty one-liners currently quoted by (0001) mp3car.com forum member sigs.
  1. Xenarc 700idt Does Not Work???
    By markcc01 in forum MacCar
    Last Post: 04-08-2007, 04:00 PM
  2. Xenarc 700IDT In DASH 7" Touch Screen IN STOCK!
    By Fiberoptic in forum LCD/Display
    Last Post: 12-15-2005, 09:12 PM
  3. Xenarc 700idt
    By DrkStormTrooper in forum LCD/Display
    Last Post: 06-01-2005, 08:40 AM
  4. XENARC 700IDT Mod
    By dan__wright in forum LCD/Display
    Last Post: 04-21-2005, 05:12 AM
  5. Xenarc Announces their 700IDT In-Dash Monitor
    By Morgon in forum Input Devices
    Last Post: 02-15-2005, 02:29 PM
