Results 1 to 10 of 16
Thread: Subaru Outback screen placement recomendations?
    Sep 2005
    I just bout a 2000 subaru outback. I am thinking about adding a touchscreen and carpc to it... Here are some question i came up with.
    Is there a way to mount a screen in a double DIN? I have only seen the install things for screens that pop out of the dash. I don't really like the looks of these at all. I also saw a double din mounting bracket for a Subaru WRX... which may work, but it was $140 which seems quite high to me.
    The screens I'm considering are:
    http://cgi.ebay.com/ebaymotors/SP-71...spagenameZWDVW
    or
    http://cgi.ebay.com/TM-868-8-TFT-LCD...QQcmdZViewItem
    sorry fo rthe long urls...
    Are those decent monitors?
    Constant Bitrate CornToeGoblin's Avatar
    Dec 2004
    Texas
    they look decent but i personally don't like big brand displays or the buttons being on the right side because it just makes it a little harder to work with
    2008 Civic... Sound system... then carputer install...
    WORK IN PROGRESS
    If you look at my avatar closely, you can see a chick with two big knockers....
    Sep 2005
    what i would like is to mount it as if it were a cd player... i dont like the brand names or buttons showing either... mainly, i dont care what the screen is, i just want to be able to mount it in the doube DIN area... so it's not sticking out at all...
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    well 8" wont fit in double din and 7" will have to removed from its casing so I would recommend getting a known brand as there will be instructions on how to take them apart on here and lots of photos and advice.
    Sep 2005
    but what about mounting plates? is this a common item? i haven't been able to find anything about it... except for that wrx thing... and $140 is quite spendy...
    Mar 2004
    Bristol
    pics of your dash would help
    Sep 2005
    i'll have to get some... it's a 2000subaru outback... it has triple din...
    Mar 2004
    Bristol
    someone did an install the other day with a new style lilliput into a 2.5 din with no fabrication at all. 3 din would leav e you will a little bit of space you could use for something creative or if you strip the screen down you could still use a HU.
    Sep 2005
    Perhaps a IDE drive... you dont happen to have a link do you?
    Mar 2004
    Bristol
    Quote Originally Posted by ahreno
    i wouldnt put an ide drive there! I would put some USB, CF slots or best of all some nice OEM style buttons to reduce the load on your TS and let you chance track and volume easier when there is glare on the screen.
    as for the link....here
  1. LCD in Ceiling of 97 subaru outback sport
    By murphy360 in forum Fabrication
    Last Post: 07-15-2005, 07:35 PM
  2. Help Quick!!! Screen Choices
    By D M N in forum LCD/Display
    Last Post: 07-14-2005, 05:16 PM
  3. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 03:16 AM
  4. Replies: 13
    Last Post: 07-02-2002, 11:54 AM
  5. NEC Versa M/75 Laptop TFT screen w/touch
    By Macgyver777 in forum LCD/Display
    Last Post: 03-24-2002, 03:14 AM
