Did you use lcdprint.exe for testing?
If not try it
peter3
Well, since I've rewired this 4x20 L2014 about 10-15 times using the original schematics (http://www.eio.com/lcd2014.htm) and modified schematics (http://www.geocities.com/krebnarb) I give up.
No one seems to know how to fix the lcd...so I'm going to have to assume that the unit is defective. I checked and re-checked the connections to many times to count..ergh.
1999 Plymouth Voyager (That's right, big-pimpin' in a minivan.)
PC built into console
worklog with pics: http://www.mp3car.com/vbulletin/worklogs/46359-1999-plymouth-voyager-computer-in-console-between-seats.html
Some of my music: http://www.myspace.com/markquestion
If not try it
peter3
PETER - THE NETHERLANDS - DEVENTER
sproggy 2.8,epia c3-800,20Gb 2.5", 5.6"lcd,touchscreen.
I hate to say it, but you might have fried the thing when you were wiring and rewiring... I've noticed that they are really sensitive to heat on the controller chips.
If you've been really careful to keep it cool, while soldering (if you actually needed to solder on the board), then it could have also been destroyed if you placed the +5v in the wrong terminal.
I killed one of these when Supermatty and a few others were figuring out the wiring scheme. I switched the positive and negative, and the whole thing was gone
I hope it works out.
-Miles
Near Completion: Intel P166 MMX, 32MB ram, 13GB Hard Drive, Keypad, 4x40 LCD. Sproggy MK2.6 ATX PSU. Win98SE with Winamp and Mark Zehnder Plugin. (Web-site: very soon)
